It is currently Thu Oct 29, 2026 5:21 pm
Post Posted: Sat Sep 18, 2010 10:06 am
just woundering can you get kits for brake cylinder i have a 1984 suzuki seairra or can you still buy them new
Vehicle: Nissan
Post Posted: Sat Sep 18, 2010 10:09 am
as in caliper kits???? then yes repco has them
Pearce-toff Racing
Post Posted: Sat Sep 18, 2010 10:27 am
i mean brake booster mine seems to leak on my feet
Post Posted: Sat Sep 18, 2010 11:23 am
just get a 2nd hand booster or get yours re-co'd..
Post Posted: Sun Sep 19, 2010 12:15 am
8O
Are you sure? For it to leak on your feet, it must be full of brake fluid.., 500ml +
The booster is outside, not inside the car..
Sure its not just water?
Post Posted: Sun Sep 19, 2010 12:20 am
8O
often when a master cyl dies the fluid comes into the cab through the pedal pushrod hole. :wink:
Vehicle: LJ50V, SJ70
Post Posted: Sun Sep 19, 2010 1:28 am
andrew15040 wrote:
just wondering can you get kits for brake cylinder i have a 1984 suzuki seairra or can you still buy them new
I mean Brake Booster
So when you say Booster, it is a 1.3lt with power assisted brakes? The 1.3 brake booster and master cylinder are the same through to a 1996 Sierra and can be readily bought new or 2nd hand. If your 1984 Sierra is a 1.0lt, there is no booster on the master cylinder as they are unassisted brakes. The mast Cyl is available new, but you might have to ring around or backorder one to find one.
If it's a 1.3 with booster, fluid can't leak from the master cyl to the pedal pushrod. This can only happen on an unboosted M/Cyl in a 1.0.
Post Posted: Sun Sep 19, 2010 9:33 am
thank you all for your answers
Users browsing this forum: Google [Bot] and 584 guests
