It is currently Fri Oct 30, 2026 8:14 am
Post Posted: Sun Sep 19, 2010 10:42 am
hey guys,anyone know where I can find a coily p/s pump kit?or if they use the same pump as the jimny...mine is leaking and its about time it gets done...think its just the front seal...
Coily GTI Turbo...thats right its a coily!!
Post Posted: Sun Sep 19, 2010 10:45 am
Is your set up from a jimny or vit? I am sure you could find something similar and much cheaper at the wreckers. Commodores and falcons have the pump and res in the single unit
Post Posted: Sun Sep 19, 2010 10:49 am
mine is genuine sierra....
Post Posted: Sun Sep 19, 2010 10:57 am
Probably a jimny one then. Good luck with that.
Post Posted: Sun Sep 19, 2010 11:02 am
i suspect its just the front seal,might just try chase one down.prehaps cbc
Post Posted: Sun Sep 19, 2010 11:06 am
Might be your best bet mate. Would work out cheaper too I would imagine
Post Posted: Sun Sep 19, 2010 1:05 pm
Take the pump to a p/s joint & have it re-coed.
save your self the headache..
BHSS down near the Vally do an awesome job, that do master's & slave's & wheel cyl's & brake hose's & all sort's O stuff..
Post Posted: Mon Sep 20, 2010 9:28 am
yeah cheers mate,pump is working great so dont need to,just the front seal leaking a bit...just hope the shaft is still ok..
Users browsing this forum: No registered users and 304 guests
