https://auszookers.com/forum/
steering issue
https://auszookers.com/forum/viewtopic.php?f=5&t=15255
Page 1 of 2
Author:  matty87 [ Mon Sep 20, 2010 9:38 am ]
Post subject:  steering issue
so fellas having played with all the steering geometry and fitted 34'' tyres with very large offset on them we are now experiencing the car tip from side to side when the steering wheel is turned.
what i mean is when you want to turn left say the car lifts up on the left hand side dramatically. as we have a p/s pump and box fitted steering is easy as two fingers can do it and i think we are getting full lock any ideas as to a problem or is this just due to the big tyres etc.
i know that on my gu troll that it does the same thing but no where near as much.
any help please.
Author:  atari4x4 [ Mon Sep 20, 2010 9:45 am ]
Post subject:  Re: steering issue
is it the rear buggy leaf set up unloading?
Author:  matty87 [ Mon Sep 20, 2010 9:52 am ]
na its all in the front end. its the front corner that lifts up on each side depending on which way you are trying to turn. a mates old man said something about caster angle but i think i have thatthe same as when it came out at the start so yeah.
Author:  JrZook [ Mon Sep 20, 2010 10:15 am ]
any help please.
Excessive caster will do it, but if you say you havent altered it I dont know what else would cause it :?
Author:  matty87 [ Mon Sep 20, 2010 10:19 am ]
any help please.
i say that but may have altered it and just am remembering wrong it was a while ago. have ya got a pic of how the diff points on a standard setup anyone?
Author:  Red89 [ Mon Sep 20, 2010 10:53 am ]
May be a by product of your shackle reversal and the front end is diving as you turn ? Whats it like under hard braking ?
Author:  MrRocky [ Mon Sep 20, 2010 10:57 am ]
simex's are mot a steel belted radial, there sidewalls move around heaps when driven on the road, thats why there not road legal, but i suspect you have other issues adding to your prob
Author:  matty87 [ Mon Sep 20, 2010 11:09 am ]
to be honest have no idea about braking etc yet as we drove it out of the shed and only went round the block haven't had a chance to do much more yet. the steering was the only really noticeable thing.
Author:  royce [ Mon Sep 20, 2010 11:17 am ]
are you saying the front jacks up turning lock to lock sitting still? if so take your foot off the brake or while moving? if so put stiffer rear springs in, springs that look cool on a ramp are shit in real life
Author:  matty87 [ Mon Sep 20, 2010 11:24 am ]
it does it sitting still. ah k the front brakes are really tight maybe thats it.
Author:  royce [ Mon Sep 20, 2010 11:56 am ]
big offset rims make the tyres turn in an arc rather than pivot, combined with any caster will do it too, the brakes on stop teh tyre rolling so push around a lot more
Author:  matty87 [ Mon Sep 20, 2010 12:04 pm ]
sweet thanks royce
i was speaking to a mate and doing some reading i think i will make up some wedges and see if i cant improve it a bit by lessening the positive castor angle. its all a rush now since its ready to go the boys wanna take it to wedge this week end so trying to sort the little problems out that we have found.
Author:  BlueSuzy [ Mon Sep 20, 2010 10:54 pm ]
Sounds like the tyres have a good grip on the concrete, and springs are soft, So they move 1st. Get someone else to steer, and you at the front. It happens to mine. But not much. Another option is run a panhard rod in the front only. That wil stop the sideways movement of the chassis to diff alignment.
Author:  DR_JOSH [ Tue Sep 21, 2010 12:44 am ]
As royce said, a lot of caster and big offset will do this. My track car does this and it runs a stupid amount of caster
Author:  matty87 [ Tue Sep 21, 2010 1:26 pm ]
had a look at the castor angle today it looks pretty standard what did the sierras come out standard with in terms of castor angle?
oh here is a bit of work from a collaboration between team rag and mothfukle engineering
more ghetto than the bronx
Author:  BlueSuzy [ Tue Sep 21, 2010 10:53 pm ]
What the hell is that??!!
Does the arm bend when you steer?
Author:  atari4x4 [ Tue Sep 21, 2010 11:57 pm ]
8O
Author:  weaves [ Wed Sep 22, 2010 2:11 am ]
Holy Z-link batman!
have you thought about using a straight draglink?
Author:  atari4x4 [ Wed Sep 22, 2010 2:21 am ]
is it just me or are the 2 spring perches different heights?
Author:  JrZook [ Wed Sep 22, 2010 2:23 am ]
x2!
Nah think one of the rulers they were using was a tad out :wink:
Author:  tanshi [ Wed Sep 22, 2010 2:29 am ]
omfg! this is why the transport authorities wanna screw with what we do to our cars!!
heard of dob in a druggie!, how about dob in a dodgy prick!
Author:  BlueSuzy [ Wed Sep 22, 2010 2:31 am ]
You failed. Its pretty much a buggy for offroad only.
But that is still a steering fail.
Author:  tanshi [ Wed Sep 22, 2010 2:32 am ]
you can bet it wont stay off road only!
Author:  BlueSuzy [ Wed Sep 22, 2010 2:34 am ]
It will break offroad! Then, never making it onroad.
Author:  tanshi [ Wed Sep 22, 2010 2:36 am ]
lets hope so, least i know the piece of crap wont ever make it as far as QLD so were still safe
Author:  matty87 [ Wed Sep 22, 2010 6:22 am ]
its not licenced guys. (the numberplates are for historic reasons only)
the drag link isnt pretty ok so its fucken ugly i did say that, as for breaking its alot stronger than a standard one and it dosent bend or more correctly flex when turning. the reason it is that way is i fabed it up neatly the first time as a trial of something else that in the end needed changing then couldnt get the right bits again to make a new one so i bodged this one up. (ill prolly make a new nice neat one when i can be bothered) :lol:
the spring perches are the same hieght the drivers side one however extends further around the axel tube as i had to make a new one for that side but could reuse the pasenger side one so when i made the new one i had it come further around the tube.
Author:  matty87 [ Wed Sep 22, 2010 6:27 am ]
But does anyone now they have recovered from throwing up or laughing at my a grade hektic fabrication skills hahaha know the answer to the castor angle question?
and also disregarding the shitness of the draglink is the angle that its on from the tierod to the pitman arm ok or is it getting a bit on the steep side?
Author:  bakerboy [ Wed Sep 22, 2010 7:21 am ]
for those of you who's most hardcore mods are fitting fluffy dice, cd player and auszookers sticker, yes its dodgy as all fuck, no it doesnt bend when turning and its not road licenced so please stfu, those that have helped earlier on in the thread, cheers guys, this is a learning experience, appreciate the knowledge your putting forth
Author:  93zook [ Wed Sep 22, 2010 7:23 am ]
it is looking a little steep...
any chnace you could post a video of what its doing?
Author:  LAY80N [ Wed Sep 22, 2010 7:33 am ]
You can measure caster by checking the angle the kingpin plates sit relative to the ground. Factory caster is 3 degrees 30 minutes (from FSM).
Layto....
Page 1 of 2 All times are UTC + 9:30 hours
