It is currently Thu Oct 29, 2026 7:28 pm
Post Posted: Tue Sep 21, 2010 5:10 am
Hey guys,
I am after some advice, I have a 91 1.6 Carby vitara soft top that I use to drive before I brought the hardtop I have currently. Its not registed and its not running at current. Im considering turning it into a little project and fixing it up.
I know this may have been covered a million times but engine wise I would prefer to change it to an EFI than fix whatever needs to be fixed to fix up the carby. hasnt been driven or started for several years and stole a few bits off it for my hardtop. Is it relitively easy to do the change over to efi? and say I did change it would it be noticably different to the carby and be worthwhile doing?
Also is there any other engines which swap over into a vitara that are reasonably easy to change over?
Post Posted: Tue Sep 21, 2010 5:13 am
The only thing that will be a "bolt up" will be the G16B....
Anything is possible, depending on how much time, effort and money that you are willing to throw at it...
I want my old sig back :(
Post Posted: Tue Sep 21, 2010 5:31 am
There will be almost as much work in fitting a EFI G16B into a carby vit as it is fitting one to a sierra.
You will still need elec mods, exhaust mods, intake and airbox mods, fuel system mods etc....
Realiasticly, how much of the work can you do yourself??
Post Posted: Tue Sep 21, 2010 5:58 am
ok thanks,
yeah true Fatzook I dont have the experience myself to do alot of it, Im the first to admit I have a quite limited mechanical knowledge. But I do know some people who I could call on for help.
Ideally if i did do it would be as a learning experience as well to try gain a bit more mechanical knowledge and hopefully pick up a few skills along the way.
But its got to be worth doing, or else im better just to fix the carby up and be done with it.
Post Posted: Tue Sep 21, 2010 6:12 am
BlackZookie wrote:
ok thanks,
The G16B is DEFINATELY worth doing IMO.
Post Posted: Tue Sep 21, 2010 6:37 am
i got a a vit at home right now in newcastle with slight side inpact but i think i would rather get a motor then rebuild it then go from there
Users browsing this forum: No registered users and 115 guests
