It is currently Thu Oct 29, 2026 2:23 pm
Post Posted: Thu Sep 23, 2010 1:22 am
this has probly been discussed many of times before, but i have a 99 model jimny on 31s and i want to bring the gearing back to pretty much standard, which is around 14 percent, is there any where i may be able to get gears for the standard jimny tcase or not????
Post Posted: Thu Sep 23, 2010 2:12 am
yes you can, http://www.trialjimny.com/jimny.html
can also fit a sierra case, with reduction gears.
Post Posted: Thu Sep 23, 2010 6:41 am
I think you'll find that you need about 20% lower gearing to gear back to stock with 31's.
Add in the higher rolling resistance and increased aerodynamic drag of the larger tyres and you will find the 24% reduction offered by the TrialJimny gears is ideal..... on road.
However, with the added grip of 31's, I don't think that 24% lower than stock gearing is not enough for offroad use.
It is possible to add the APIO low range planetary set with the trial jimny gears for a low range of about 5.2:1 (pretty sweet with 31's) but you'll have to weigh up if that's too much money to tip into a jimny case and you're better off starting off with a gear drive sierra case.
Post Posted: Thu Sep 23, 2010 7:28 am
im looking into putting a sierra transfer into mine. the trial jimny gears are about 1200-1500ish.
Post Posted: Thu Sep 23, 2010 10:30 pm
stuff that, i had a wide track standard tcase in the shed, might just put that in with out changing the ratio because thats lower then the jimny any way as far as i know, does that sound right
dodgy brothers mechanical
Post Posted: Thu Sep 23, 2010 10:45 pm
i run 5.14 calmini tcase gears on my sierra with 31's and on road and off its geared spot on...
i'd suggest the same for a jimny on 31s.
if you're going to the effort of chucking a sierra case in you might as well open it up and rebuild it with a gear set.
Post Posted: Fri Sep 24, 2010 2:10 am
yea, just was thinkin of bringin it backto standard ratio becase on the beachi dnt wanna have to takle the dunes in 5th gear like friends have toin the sierras
Post Posted: Fri Sep 24, 2010 4:37 am
thats right.... 5.14 tcase is about 19% lower, and 31's are about 19% bigger...
Users browsing this forum: Google [Bot] and 332 guests
