It is currently Thu Oct 29, 2026 7:28 pm
Post Posted: Tue Sep 28, 2010 11:21 am
What will i need for my transfer case and mounts when adding 6.5s? I will be getting a roctoy ring, do i need strenghtened mounts or any other add on?. Only running stock 1.3, will have mini spool in shortly, on 31s.
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Tue Sep 28, 2010 11:35 am
rocktoy ring should be all with only 31's but depends how hard you drive, ive got no bracing or anything on 33s and haven't done any damage...yet
Post Posted: Tue Sep 28, 2010 12:04 pm
i have a roctoy ring with a few flatbar gussets back to the standard mounts.i also have some strengthening on my standard mounts,i have a piece of 6mm flat welded on the single mount to try stop it bending,and some gussets on the long arm along it,filling across the angle to stop it twisting like i have seen many do.
i run 6.5s,31s,rear locked for 2 n a half years and now front for 2 trips havent had any damage so far thank god,not even a torn standard rubber mount.also have 65x35rhs to lift the case
Post Posted: Tue Sep 28, 2010 8:51 pm
Is this http://locktup4x4.com.au/index.php?main ... ge&pID=392 any good?
Post Posted: Wed Sep 29, 2010 12:25 am
maloo11 wrote:
Personally I think running standard rubber mounts is best, on the basis that if there is gonna be a weak point I'd rather it be a cheap mount than the case...
I want my old sig back :(
Users browsing this forum: No registered users and 116 guests
