Joined: Sun Sep 12, 2010 7:58 am Posts: 11 Location: NZ
Posted: Sat Oct 02, 2010 11:16 pm
so i bought a set of castor corrected bushings for my coily with a 40mm spring lift but when i took the front arm off I couldn't get the old rubber bushings out.
Is a press needed to remove them or is there a trick I haven't figured out yet?
Cheers, Kent
Press is the only way to go! Make sure the socket or thing u use to press old ones out is the same or a touch smaller than the metal outercasing of the original bush! If you tear the rubber with the metal casing still in the arm it's a pain.
_________________ 1997 Sierra, daily driver, 60mm coils, 2 inch body
Posted: Sun Oct 03, 2010 3:37 am
Cheers guys. ill try borrow a press next weekend and punch them out.
Also I gave my truck a nice clean and took some photos so I will post them real soon.
Joined: Mon Jul 26, 2010 9:55 am Posts: 27 Location: Darwin
Posted: Tue Oct 05, 2010 1:38 am
I am going to be doing a 40mm lift on my coily in the near future, do i need worry about caster correction?
Also is the ebay lift kit worth getting?
Posted: Tue Oct 05, 2010 2:12 am
well i havent got them in yet but once i done my suspension lift i felt the castor was effecting the steering. not badly but it was there.
Best thing I bought was the return to centre steering dampener of ebay.
Makes mud tyres on the high way muuuch nicer
Users browsing this forum: No registered users and 434 guests
