It is currently Fri Oct 30, 2026 4:55 pm
Post Posted: Mon Oct 04, 2010 9:02 am
what is the best and fastest way to find a small puncture? takes 4 days to deflate from 30-0psi
Post Posted: Mon Oct 04, 2010 9:06 am
take the wheel off and throw it in someones pool =P
ORRRRRR 50/50 mix of detergent and water, and slowly brush it around the valve stem, valve, and bead on both sides... if you dont see any bubbles blowing then slowly work your way around the sidewall then the tread.
Post Posted: Mon Oct 04, 2010 9:09 am
Is the most common....if it is that, just let all the air out & spray silicone spray in between the rim & the bead, save's stripping the tyre..
Post Posted: Mon Oct 04, 2010 9:59 am
thanks heaps much appreciated!
Vehicle: 4wd
Post Posted: Mon Oct 04, 2010 10:06 am
Check your valve first.
Watch out or you'll get sued.
Post Posted: Mon Oct 04, 2010 10:54 pm
Or take to a shop. $20 well spent.
Post Posted: Tue Oct 05, 2010 5:05 am
orrrrrr....
i dunno i just wanted to write or again.
Post Posted: Tue Oct 05, 2010 5:26 am
Pet shop?? :P
Users browsing this forum: No registered users and 395 guests
