It is currently Fri Oct 30, 2026 4:55 pm
Post Posted: Tue Oct 05, 2010 3:35 am
hey guys, took the head off the zook to replace the headgasket and to find a crack in the block between 2nd and 3rd cylinder, have spoken to 2 mechanics both say where the crack is shudnt be much of a problem but 1 has told me to use GM sealer on both sides of the new head gasket as it is apparently top stuff then run chemiweld through the radiator, the other said dont use GM sealer because it will probably react to the glue already on the gasket. This will still only be a temp fix just to run me to a few job interviews over the nxt couple of months, then il replace the whole engine, just wanted to hear some thoughts from guys on here on what i should do.
cheers in advance
Post Posted: Tue Oct 05, 2010 3:45 am
Just look around for a cheap bottom end. I wouldn't be too surprised if someone has one lying around that they are wanting to get rid of.
Post Posted: Tue Oct 05, 2010 3:53 am
i have one for you $50
Think before you post to make AZ a better place :)
Post Posted: Tue Oct 05, 2010 4:04 am
Almost as cheap as a bottle of shit that is as useful as a cock flavoured lollipop :P
Vehicle: 2018 DMAX
Post Posted: Tue Oct 05, 2010 4:41 am
Ive got a whole engine for $50... needs rebuild but should have a good ass end.. not that far to drive :D
Post Posted: Tue Oct 05, 2010 4:44 am
20mins vs 12 hours...
Post Posted: Tue Oct 05, 2010 4:58 am
might have found a complete engine guys, but ck that block you have is that complete, pistons, crank etc or just the block on its own?
Post Posted: Tue Oct 05, 2010 5:05 am
block with pistons, crank etc. engine mounts are broken. no starter.
it came out of a 95 sierra i parted and i was told the rings had gone in it
Users browsing this forum: No registered users and 395 guests
