https://auszookers.com/forum/
Any difference between the front diff and the rear diff
https://auszookers.com/forum/viewtopic.php?f=5&t=15703
Author:  barlow [ Thu Oct 07, 2010 10:53 am ]
Post subject:  Any difference between the front diff and the rear diff
Just wondering if there is any difference in the front and rear diffs. thinking of taking my front diff off my donor car and using it as a rear with my mini spool can i do this???
Author:  Fatzook [ Thu Oct 07, 2010 10:58 am ]
Post subject:  Re: Any difference between the front diff and the rear diff
Nope.
Front is 22 spline, rear is 26 spline.
Author:  barlow [ Thu Oct 07, 2010 11:00 am ]
shit!!! what about if i have some 3.9 gears in a rear nt diff can i used them in a wt diff??
Author:  Rhino [ Thu Oct 07, 2010 11:08 am ]
Front diff can be used as a rear with your minispool as it will replace the sidegears...
3.9 can be used in a wt diff u just need to swap the flange............and the front diff to 3.9 as well
Author:  Fatzook [ Thu Oct 07, 2010 11:08 am ]
You can us ethe centre. But unless you change the front diff to NT gears aswell you will have some issues when it comes time to engage 4wd :lol:
Author:  whincup [ Fri Oct 08, 2010 4:24 am ]
or just run slightly bigger tyres on the back...
Author:  steak_knife [ Fri Oct 08, 2010 9:45 am ]
Nope.
:? spool's have their own splines.
http://www.lowrangeoffroad.com/suzuki/s ... spool.html
