It is currently Sat Oct 31, 2026 12:54 am
Post Posted: Sun Oct 10, 2010 8:48 am
is it possible to replace the seal that sits around the splined shaft that the pitman arm attatches to, without removing the steering box from the car, its a job my stupid big hands dont like doing very much.
Post Posted: Sun Oct 10, 2010 9:08 am
if you can get the pitman arm off while it's in the car (good luck with that) then you probably can do it. getting the seal out with the shaft still in place is going to be tricky though, and access is only going to make it worse.
you would be better off spending the 10 minutes it takes to pull the box out of the car to do it, then you could replace the steering column shaft seal aswell.
Post Posted: Sun Oct 10, 2010 9:29 am
i undid the big ass bolt with my rattle gun then stuck my gear puller on the job.... i also used my rattle gun on the puller, not recomended but works :lol:
Post Posted: Sun Oct 10, 2010 10:02 am
yeah ive had the pitman arm off but the blowtorch i used and the massive hammer may have had an adverse affect on the seal 8O
Post Posted: Sun Oct 10, 2010 10:05 am
Throw both box & pitman in the bin..
Post Posted: Sun Oct 10, 2010 10:06 am
Where do you get the seals for the steering box, are they kit form or do you have to buy individually.
Does anyone know the Part #s
Users browsing this forum: No registered users and 386 guests
