It is currently Sun Nov 01, 2026 2:39 am
Post Posted: Thu Oct 14, 2010 10:48 pm
Hey dudes,
my clutch is stuffed... to much mud a water :x
so which clutch should i go for? I'm twin locked running silvertone extremes, so i'm thinking some sort of heavy duty clutch.
Not sure which brand to go for and if i should just get one through repco or USA...
Thanks in advance...
RPM
Post Posted: Fri Oct 15, 2010 12:14 am
Do you have transfer gears?
If yes, a standard clutch will be fine.
Post Posted: Fri Oct 15, 2010 12:21 am
i have 5.1 dif gears and also i have a fully rebuilt transfer case with reduction gears waiting to be installed... thanks want33's
Post Posted: Fri Oct 15, 2010 1:10 am
My swb, i run a stocko replacement clutch, 6.5's with rear locked on 33's. Never had a drama.
My lwb i am getting the petroworks HD one on lowrange to test. (may need it for twin locked , 35's, lux/bund diff)
Post Posted: Fri Oct 15, 2010 5:03 am
i should of mentioned that i have the vitara 5sp manual gearbox as well...
Post Posted: Fri Oct 15, 2010 5:55 am
I'd use a stock genuine parts clutch if you have decent gearing. They seem the most durable and most heat resistant.
Users browsing this forum: Google [Bot] and 71 guests
