| Trying to work out the problem.. f8a motor https://auszookers.com/forum/viewtopic.php?f=5&t=15956 |
| Author: | something_else [ Fri Oct 15, 2010 1:31 pm ] |
| Post subject: | Trying to work out the problem.. f8a motor |
Well it started and idle'd fine when i bought it but when you went to rev the engine it would die.. i figured it was one of the jets but this is not the case.. spark and fuel pump are both fine.. the car will not start at all now. and i think i have narrowed it down to timing? maybe timing belt has slipped 1 tooth. or the coil//dizzy is on its way out. what do you guys think? |
| Author: | steak_knife [ Fri Oct 15, 2010 7:13 pm ] |
| Post subject: | Re: Trying to work out the problem.. f8a motor |
Welcome to the wonderful world of POINT'S!!!
| Author: | want33s [ Fri Oct 15, 2010 7:53 pm ] |
Drop a 1.3 dissy in to get rid of the points. Will eliminate one potential problem. I just put a 1.3 dissy into my 1.0 ute. I removed the advance springs from the F10 dist. and fitted them to the G13 unit. Works great. Get rid of the ballast resistor too. |
| Author: | hutch [ Fri Oct 15, 2010 9:11 pm ] |
1 Check the solonoid on the carby... it will have a thin black and white wire going to it from memory when I had an F8A in my LJ. If this connection is brokded it wont start, or idle well. 2 Alternativly chck Coil wires etc. 3 Scatch head |
