It is currently Tue Nov 03, 2026 1:34 am
Post Posted: Mon Dec 20, 2010 12:23 pm
hey guys wondering where about's in perth or south WA you can get custom springs made.
i wont to get them made 50 - 75mm longer, my shackles are near straight wile jus sitting there. :?
yes i have serched but couldnt find any in these area's. also i dont wont to get other springs as i dont really feel like relocating the diff.
cheers scott 8)
Post Posted: Mon Dec 20, 2010 12:33 pm
try http://www.westraliasprings.com.au/ or http://www.industrialsprings.com.au/contact.htm in SA
Post Posted: Mon Dec 20, 2010 8:38 pm
A main and full length second is all you will need. Then use your existing to fill underneath.
Post Posted: Mon Dec 20, 2010 9:49 pm
ok guys thanks
Post Posted: Tue Dec 21, 2010 9:49 am
I got my first set through Westralia springs however the 2nd set I needed they no longer did custom leaves under 8mm thick ( Sierra's are 6mm I think ) They could order it in but that was going to add $80 each leaf. So the 2nd set I got made at Suspension Man in Bellevue, not cheap at about $90 per leaf. Make sure you have all your measurements, dont just walk in and say you want a leaf that is a couple inches longer. You need the straight across eye to eye measurement, the bush size, the eye to pin measurement for each end following the curve, the camber/height measurement and material thickness needed. Also dont forget to tell them it is for a vehicle weighing around 1000kg, I forgot to do this the second time and he made them too stiff :oops:
Users browsing this forum: Google [Bot] and 575 guests
