| new engine installation https://auszookers.com/forum/viewtopic.php?f=5&t=16566 |
| Author: | andy1517 [ Mon Nov 08, 2010 12:13 am ] |
| Post subject: | new engine installation |
Guys, Im having my 1.3 rebuilt at the moment, and therefore I am trying to get myself organised so i can install the engine. I am wondering, after installation, and hooking everything up, and filling with oil and coolant. Is it as simple as just cranking the engine over? Or do I need to stuff around with oil pressure and other stuff? Also, when i refit dizzy and other bits, will it run the same as it use to, ie? Do i have to change the timing? Any information would be appreciated. Its a 94 swb sierra, 1.3 |
| Author: | JrZook [ Mon Nov 08, 2010 12:23 am ] |
| Post subject: | Re: new engine installation |
andy1517 wrote: Guys,
Im having my 1.3 rebuilt at the moment, and therefore I am trying to get myself organised so i can install the engine. I am wondering, after installation, and hooking everything up, and filling with oil and coolant. Is it as simple as just cranking the engine over? Or do I need to stuff around with oil pressure and other stuff? Also, when i refit dizzy and other bits, will it run the same as it use to, ie? Do i have to change the timing? Any information would be appreciated. Its a 94 swb sierra, 1.3 Its always a good idea to disconnect the ignition and wind it over until you get some sort of oil pressure (no oil light on). The G series build up pressure pretty quick so maybe 5-10secs cranking on the fresh engine should see the oil light off. This cranking time should also fill the carby bowl with fuel as well. Shouldn't have to change the timing but you should set it to spec once the engine is running. |
| Author: | andy1517 [ Mon Nov 08, 2010 12:25 am ] |
Quote: Shouldn't have to change the timing but you should set it to spec once the engine is running.
Does this mean as by the manual? I want to get the carby tuned by a mechanic, Maybe I will get him to adjust timing at the same time. Thoughts? |
| Author: | JrZook [ Mon Nov 08, 2010 12:31 am ] |
andy1517 wrote: Quote: Shouldn't have to change the timing but you should set it to spec once the engine is running. Does this mean as by the manual? I want to get the carby tuned by a mechanic, Maybe I will get him to adjust timing at the same time. Thoughts? Correct. I believe its between 8-10 degrees BTDC @ ~850RPM. You will need a timing light to set it to that spec. |
| Author: | 303zuke [ Mon Nov 08, 2010 2:53 am ] |
JrZook wrote: andy1517 wrote: I am wondering, after installation, and hooking everything up, and filling with oil and coolant. Is it as simple as just cranking the engine over? Or do I need to stuff around with oil pressure and other stuff? Any information would be appreciated. Its a 94 swb sierra, 1.3 Its always a good idea to disconnect the ignition and wind it over until you get some sort of oil pressure (no oil light on). The G series build up pressure pretty quick so maybe 5-10secs cranking on the fresh engine should see the oil light off. This cranking time should also fill the carby bowl with fuel as well. When you crank it as above, take the spark plugs out so you're not labouring the starter against the compression of the cyls. |
