It is currently Sun Nov 01, 2026 11:40 am
Vehicle: Vitara 90'
Post Posted: Mon Nov 08, 2010 7:06 am
Hi Guys,
I've had a quick look on ebay and there seem to be a couple of universal bump stops. Since I won't be getting my lift until next year I want to get some bumpstop extensions just to help with the bigger wheels scrubbing.
Basically I'm stumped as to which ones to get below is a link to one I was thinking about, what do you think?
And do I just get some bolts and washers from bunnings or what?
http://cgi.ebay.com.au/UNIVERSAL-BUMP-S ... 45f55b04bc
Thanks in advance. :D
Post Posted: Mon Nov 08, 2010 7:14 am
if u can get hold of a welder there not hard to make extensions
just need to weld a bolt and nut on to to bits of plate then weld them on to a bit of pipe the length u need
or better option would be to weld a top on a pipe and weld it to the bottom spring seat
as the top method rubs on the springs
Post Posted: Mon Nov 08, 2010 7:47 am
http://auszookers.com/index.php?name=Fo ... ump#109858
XL-7 front bumpstop extensions ARB part #FK28, most ARB stores have no idea ARB/OME make it.
Vehicle: Vitara 90'
Post Posted: Mon Nov 08, 2010 8:53 am
Sweet Thanks for the tips guys. I've got a welder didn't even think of something like that, I might try a removable one.
Thanks for the Link Atari, I tried for a min to search but no luck.
Users browsing this forum: Google [Bot] and 432 guests
