It is currently Sun Nov 01, 2026 11:42 pm
Post Posted: Mon Nov 08, 2010 11:36 pm
so was looking at my towing plug looks like its been cut. Any ideas on where to get another one? And a wiring diagram?
Also to to do with towing..
You reckon I could tow a car trailer with a Holden gemini on it? I suspect proberly not but thought I would ask everyones opinion?
Vehicle: '92 Sierra
Post Posted: Mon Nov 08, 2010 11:38 pm
Supercheap has standard plugs, both round and flat. The packet comes with it's own wiring diagram with colours provided your trailer has the right trailer cable used when built. Mine is about 25 years old and the colours are still correct so you should be ok.
Vehicle: 94 Vitara LWB G16b
Post Posted: Tue Nov 09, 2010 12:12 am
A sierra towing a car trailer?
I wouldnt' try it, even without a car on it. But I have seen people do crazier things. I am sure it would be dangerous and illegal, even if it was possible.
94 Vitara LWB G16b
Post Posted: Tue Nov 09, 2010 12:14 am
Pin 1 - Yellow - Left-hand turn indicator
Pin 2 - Black - Reversing signal
Pin 3 - White - Earth return
Pin 4 - Green - Right-hand turn indicator
Pin 5 - Blue - Service brakes
Pin 6 - Red - Stop lamps
Pin 7 - Brown - Rear lamps, clearance and side marker lamps
Image7 pin socket(female).
Image7 pin plug (male).
A Sierra is allowed to tow 450Kg MAXIMUM...... A car trailer alone would be more than that...
Post Posted: Tue Nov 09, 2010 2:34 am
it is in the tech section
http://auszookers.com/index.php?name=Topics
Post Posted: Tue Nov 09, 2010 6:07 am
cheers guys :)
thought I would ask before towing up and down springbrook mountain with the gemini.... hahaha
Post Posted: Tue Nov 09, 2010 7:20 am
Drive the Suzuki out with the trailer, put the Sierra on the trailer and tow it back with the Gemini! :)
Users browsing this forum: Google [Bot] and 387 guests
