It is currently Mon Nov 02, 2026 11:31 am
Post Posted: Tue Nov 23, 2010 8:25 pm
Hi I am looking at getting a 2nd hand arb bar fr my vitara but just want to check that one off a 91 swb will fit a 96 swb. Are the mounts any different?
Also on a sidenote has anyone else used e-go as a courier and have positive feedback for them?
Jono
Post Posted: Tue Nov 23, 2010 10:32 pm
Jono
I use them for everything. 40 or so items sent with them so far. Not one drama yet. 8)
Post Posted: Tue Nov 23, 2010 10:58 pm
Jono
Looking at my ARB price list, they list one for all of the SWB's & a different one for the LWB. The SWB part number is 3426010, not sure if it's actually stamped somewhere on the bar.
Post Posted: Tue Nov 23, 2010 11:25 pm
Thanks fatzook e-go sounds good I will give them a try.
Cheers atari that helps I might give arb a call and did out from them I know the towbars are different for early model swb but wasn't sure about bullbars.
Post Posted: Tue Nov 23, 2010 11:52 pm
They may use the same bar but different mounting brackets.
I'd call and check with ARB before parting with the foldy stuff.
Post Posted: Tue Nov 23, 2010 11:54 pm
To the very best of my observation all 1.6 SWB vits are teh same chassis
Post Posted: Tue Nov 23, 2010 11:56 pm
Inc X-90? I should know. I've owned 4 x-90 front cuts now. :roll:
Post Posted: Wed Nov 24, 2010 12:41 am
mine is essentially an X90 in a lot of areas, things like engine mounts appear to differ to earlier ones but the way the bar attaches seems to be the same as early ones
Post Posted: Wed Nov 24, 2010 1:34 am
now you say it i'm sure there is any early & late chassis, the early SWB's have the tube front cross member similar to the Sierra & I think the later SWB's were more like the LWB.
I'm trying to find some pics....
Post Posted: Wed Nov 24, 2010 1:54 am
mine is jan 96, so not many later 1.6 around and it is tube front
I remember seeing that there is 2 wagon chassis though, with ARB listing different bars
Post Posted: Wed Nov 24, 2010 1:56 am
that might be it then, if yours is tube then all of them will be tube as Polar_Bears carby SWB is also the same.
Post Posted: Wed Nov 24, 2010 5:04 am
Cheers guys,
Rang ARB they can confirm that their SWB bar will fit any SWB or if you buy a LWB bullbar it will fit any LWB (other than SV series)
They have 2 part numbers one being SWB the other LWB
Also rang a wreckers to ask as well The standard front bumpers are different. Up to 94 is one style then it changes for the later ones. But the way they mount to the chassis the same. It is the reinforcement and design of the plastic cover that change.
Users browsing this forum: No registered users and 446 guests
