It is currently Sun Nov 01, 2026 12:53 am
Post Posted: Wed Nov 24, 2010 11:36 am
Hi I am trying to fit 2 wheel drive to our sidecar setup.
I Need some advice please.
I though what better place to ask than a Suzuki forum :)
The hub I am looking for will have to be manual free wheeling and the drive shaft will need to have a bolt up flange on the end that goes to the gearbox.
(Or to a center shaft flange in my case)
I was Looking to use something like our 99 vintara grand front hubs .
But It would have to be a manual hub to free the drive to the sidecar wheel when not needed.
(Question ) Would a vintara front hub be good to use or are there other model hubs that would make it easy and cheaper to get free wheeling hubs?
Any advice ideas would be great.
Photo is not of my bike but just to give you a idea of what i am trying to do
Thanking you Ian.
Post Posted: Wed Nov 24, 2010 11:48 am
Sounds like a killer set up, would be interested to hear how well it works.
The front LHS of the Vitara/Grand Vitara run a bolt in CV with a 3 bolt flange. The Grand Vitara run a fixed drive flange instead of a Free Wheeling hub, the Vitara has a FWH.
The left & right half shafts are slightly different lengths & there is also a longer version for the SV420 & SV620 2.0l Vitara's, the outer spline count is 26, not sure on the diameter.
Hopefully these pics might shed some light.
Post Posted: Wed Nov 24, 2010 11:53 am
EDIT: I'm pretty sure the aisin freewheeling hubs off a hilux will also fit on the end of the Vitara CV as I think they are also 26 spline
Post Posted: Thu Nov 25, 2010 3:06 am
Thank you atari4x4. :D
That should work out ok.
I have just brought a cheap hub and shaft from ebay,no real loss if it don't work out .
I will post a photo when it is done.
Thanking you Ian
Post Posted: Thu Nov 25, 2010 3:32 am
Does that mean the Aisin hubs off a hilux will also fit a GV (1999)? I'm looking to get a pair of hubs and that may be a cheaper option. There are a few Hilux hub versions? Any idea which one will fit?
Post Posted: Thu Nov 25, 2010 4:26 am
I have a pair of Vitara locking hubs here that will fit GV as well.
Users browsing this forum: Google [Bot] and 87 guests
