It is currently Tue Nov 03, 2026 2:25 pm
Post Posted: Mon Dec 13, 2010 10:47 pm
I'm up for changing my rear diff oil and am wondering what weight oil I should use.
I have an airlocker as well.
The factory manual says 80W90 GL5, I've just phoned ARB and they say:
Normal use: Shell diff oil (SAE90)
Mobilube GX90
Heavy use: Shell Spirax 85W-140 (GL5)
Mobilube GX140 (GL4)
Now, I have Vitara gears (5.12) that are a bit noisy at certain speeds, probably due to age.
Would going a heavier weight diff oil be beneficial to longer life etc? I've run these gears for 3+ years and it sounds the same so is not getting worse. I'm thinking about going the Shell Spirax 85W-140. Do you guys recommend others?
What are the implications of running heavier weight oil? - Increased resistance due to a thicker oil being spun around???
2002 SWB GV
Lifted and Locked
Post Posted: Tue Dec 14, 2010 12:19 am
My personal preference/belief would be standard grade oil if in cooler climates, as heavy oil can give drive resistance until warmed up.
But I would add a diff oil conditioner/additive to help with the noise.
Post Posted: Tue Dec 14, 2010 12:36 am
Yes I will be adding the Nulon stuff as well.
The change in the heavier gear oil is only the hot temperature viscosity, from 90 to 140 so I suppose it'll take longer to get warmed up.
2002 SWB GV
Lifted and Locked
Post Posted: Tue Dec 14, 2010 12:54 am
I have alwyas used 85/140 in my diffs with air lockers. Never had a worry.
Post Posted: Tue Dec 14, 2010 2:18 am
Go the heavier one, any extra weight down low helps sierras
Post Posted: Tue Dec 14, 2010 2:28 am
doesnt really help so much as i have a navara .. but i run lsd oils in both my diffs rear lsd also in my transfer and gear box.. its bit thicker and while cold is a smidge harder to shift .. but i feel it protects my cogs and stuff a bit better so i can live with a stiff shift of a morning
-indebt 4x4 club-
nav 32s n winch cust rear
Vehicle: MY2019 Jimny
Post Posted: Tue Dec 14, 2010 6:12 am
Armsup Armsup Armsup
Post Posted: Wed Dec 15, 2010 10:42 pm
Do people still recommend using LSD oil in airlocked diffs? Something about the additives being better for the seals???
The ARB list standard oils.
2002 SWB GV
Lifted and Locked
Post Posted: Wed Dec 15, 2010 11:02 pm
i run normal castrol oil in mine as per arb's specs.
Post Posted: Thu Dec 16, 2010 12:08 am
Does brand matter as ARB only recommend Shell or Mobil? (assuming I'm using the same grade)
2002 SWB GV
Lifted and Locked
Post Posted: Thu Dec 16, 2010 12:11 am
i doubt brand will really make much difference.
i run standard epx90 in my airlockers
Post Posted: Thu Dec 16, 2010 1:45 am
Would going fully synthetic be worth it, eg CASTROL SYNTRAX 75W-90?
2002 SWB GV
Lifted and Locked
Post Posted: Thu Dec 16, 2010 2:06 am
Not IMO. And if you are doing regular diff oil changes, you would just be throwing your money away.
Post Posted: Thu Dec 16, 2010 10:58 pm
Thanks all,
I've settled on Castrol EPX 80W90 plus some Nulaon diff additive.
2002 SWB GV
Lifted and Locked
Users browsing this forum: No registered users and 506 guests
