| Using heavier weight oil in airlocked diff https://auszookers.com/forum/viewtopic.php?f=5&t=17497 |
| Author: | TheOtherLeft [ Mon Dec 13, 2010 10:47 pm ] |
| Post subject: | Using heavier weight oil in airlocked diff |
I'm up for changing my rear diff oil and am wondering what weight oil I should use. I have an airlocker as well. The factory manual says 80W90 GL5, I've just phoned ARB and they say: Normal use: Shell diff oil (SAE90) Mobilube GX90 Heavy use: Shell Spirax 85W-140 (GL5) Mobilube GX140 (GL4) Now, I have Vitara gears (5.12) that are a bit noisy at certain speeds, probably due to age. Would going a heavier weight diff oil be beneficial to longer life etc? I've run these gears for 3+ years and it sounds the same so is not getting worse. I'm thinking about going the Shell Spirax 85W-140. Do you guys recommend others? What are the implications of running heavier weight oil? - Increased resistance due to a thicker oil being spun around??? |
| Author: | christover1 [ Tue Dec 14, 2010 12:19 am ] |
| Post subject: | Re: Using heavier weight oil in airlocked diff |
My personal preference/belief would be standard grade oil if in cooler climates, as heavy oil can give drive resistance until warmed up. But I would add a diff oil conditioner/additive to help with the noise. |
| Author: | TheOtherLeft [ Tue Dec 14, 2010 12:36 am ] |
christover1 wrote: My personal preference/belief would be standard grade oil if in cooler climates, as heavy oil can give drive resistance until warmed up.
But I would add a diff oil conditioner/additive to help with the noise. Yes I will be adding the Nulon stuff as well. The change in the heavier gear oil is only the hot temperature viscosity, from 90 to 140 so I suppose it'll take longer to get warmed up. |
| Author: | Bruce [ Tue Dec 14, 2010 12:54 am ] |
I have alwyas used 85/140 in my diffs with air lockers. Never had a worry. |
| Author: | 11_evl [ Tue Dec 14, 2010 2:18 am ] |
Go the heavier one, any extra weight down low helps sierras |
| Author: | BUZOOKA [ Tue Dec 14, 2010 2:28 am ] |
doesnt really help so much as i have a navara .. but i run lsd oils in both my diffs rear lsd also in my transfer and gear box.. its bit thicker and while cold is a smidge harder to shift .. but i feel it protects my cogs and stuff a bit better so i can live with a stiff shift of a morning |
| Author: | lump_a_charcoal [ Tue Dec 14, 2010 6:12 am ] |
11_evl wrote: Go the heavier one, any extra weight down low helps sierras
| Author: | TheOtherLeft [ Wed Dec 15, 2010 10:42 pm ] |
Do people still recommend using LSD oil in airlocked diffs? Something about the additives being better for the seals??? The ARB list standard oils. |
| Author: | atari4x4 [ Wed Dec 15, 2010 11:02 pm ] |
i run normal castrol oil in mine as per arb's specs. |
| Author: | TheOtherLeft [ Thu Dec 16, 2010 12:08 am ] |
atari4x4 wrote: i run normal castrol oil in mine as per arb's specs.
Does brand matter as ARB only recommend Shell or Mobil? (assuming I'm using the same grade) |
| Author: | tanshi [ Thu Dec 16, 2010 12:11 am ] |
i doubt brand will really make much difference. i run standard epx90 in my airlockers |
| Author: | TheOtherLeft [ Thu Dec 16, 2010 1:45 am ] |
Would going fully synthetic be worth it, eg CASTROL SYNTRAX 75W-90? |
| Author: | Fatzook [ Thu Dec 16, 2010 2:06 am ] |
TheOtherLeft wrote: Would going fully synthetic be worth it, eg CASTROL SYNTRAX 75W-90?
Not IMO. And if you are doing regular diff oil changes, you would just be throwing your money away. |
| Author: | TheOtherLeft [ Thu Dec 16, 2010 10:58 pm ] |
Thanks all, I've settled on Castrol EPX 80W90 plus some Nulaon diff additive. |
