It is currently Tue Nov 03, 2026 2:45 pm
Post Posted: Mon Dec 20, 2010 8:29 am
my passenger side engine mount has broken are the vl ones worth upgrading to, they seem to be priced the same, is it just a matter of grinding off the locator on the vl mount and fitting it, or is there some secret squirrel business, can i just fit the broken one or do i need to do both at the same time. the engine torques to the drivers side so i spose its the safe to assume the passenger side mount is normally the first to go.
Vehicle: 4wd
Post Posted: Mon Dec 20, 2010 8:37 am
I think the drivers side is the first to go.
I have a new set you can have for $25 posted.
Watch out or you'll get sued.
Vehicle: I drive your mum
Post Posted: Mon Dec 20, 2010 8:39 am
When you load the motor up in forward gears the torque puts the drivers in compression and the passengers in tension. The passenger side often tears, whilst the drivers side ends up crushing itself to failure.
Layto....
Post Posted: Mon Dec 20, 2010 8:53 am
cheers but i need a replacement asap and the postage system seem to suck bigtime at the moment
Users browsing this forum: No registered users and 71 guests
