It is currently Tue Nov 03, 2026 1:29 am
Post Posted: Tue Dec 21, 2010 8:57 am
The Gv has developed a timing chain noise. how do i fix it. wasn't this noisy last week. It had a noisy lifter but went away after it ran for some time. How do i fix this noisy timing chain.
Post Posted: Tue Dec 21, 2010 9:05 am
Run an engine oil flush and repeat every service, use a light weight oil.
I use diesel engine oil and Service it religiously my h20 has 270000 klms and doesn't make a sound except for a sticky lifter after not running for a couple days.
Post Posted: Tue Dec 21, 2010 9:25 am
Copied from you build thread.. he's on the money..
gregdixon wrote:
I give it a good high rpm high load run. Lets the tensioner jump another tooth and keep the chain tight.
Post Posted: Tue Dec 21, 2010 9:30 am
Is this something in the design? I've never heard of that one
Vehicle: 2004 SQ625 GV
Post Posted: Tue Dec 21, 2010 9:33 am
It's a ratcheting tesioner. Just needs a little help.
Post Posted: Tue Dec 21, 2010 9:38 am
The H20's have a "modified" tensioner you can get from suzuki, it replaced the ole one when they were still in wty, if you buy a new one you get the modified one..
The ratchet teeth are to far apart form them to adjust easily, so we help em by giving em a lil drive..
Post Posted: Tue Dec 21, 2010 9:47 am
Ok makes sense. So if one of these engines are babied their whole life they will have a noisier chain than one that's been driven harder?
Post Posted: Tue Dec 21, 2010 9:55 am
They like to work, but saying one will be better than the other??Can't answer for sure, but regular servicing with flush & not skimping on oil is a MUST!!!
Post Posted: Tue Dec 21, 2010 9:59 am
Mines a H25A. is it the same deal?
Post Posted: Tue Dec 21, 2010 10:06 am
Thay used what was learned from the H20's, but still not enough as far as I'm concerned..even the H27's in the Jb's do it..
Vehicle: Sold zuk got a Bt50
Post Posted: Tue Dec 21, 2010 10:42 am
Yeah I have learnt/learning to live with mine I always drive mine hard now noise has quietened a lil but not much regular oil also helps
Post Posted: Wed Dec 22, 2010 4:00 am
hard rev under load did the job. all quiet now.
Users browsing this forum: Google [Bot] and 587 guests
