It is currently Mon Nov 02, 2026 6:31 pm
Post Posted: Wed Dec 22, 2010 2:43 am
Yesturday arvo my car (96 vitara efi) developed a bit of a missfire when under load only every now and then so i got new spark plugs and missfire is gone :D
but looking at the plugs i took out there is oil on the thread and black crap around the top of the threaded bit :? but the bit that sparks is sort of white :? :?
These plugs are about 15,000 to 20,000 kms old if that helps
Cheers Joe
Vehicle: 03 Jimny
Post Posted: Wed Dec 22, 2010 3:09 am
oil or fuel additives, bad fuel, might be oil ash
Post Posted: Wed Dec 22, 2010 3:30 am
When it started to miss yesturday i put in a bottle of injector cleaner
Im more worried about the oil on the thread and the black crap on the top :?
Vehicle: 4wd
Post Posted: Wed Dec 22, 2010 3:38 am
The oil on the out side and on the thread could be coming from the rocker cover.
Watch out or you'll get sued.
Post Posted: Wed Dec 22, 2010 3:39 am
Nah no leaks that i can see :?
Post Posted: Wed Dec 22, 2010 3:43 am
under the rocker cover there are 4 little rubber washers that seal between the cover and the tubes the sparkplugs sit in, they are leaking into the tubes, which also then shorts out the ends of the leads :)
Post Posted: Wed Dec 22, 2010 3:51 am
Bugger :evil: ill pull it apart and fix it once ive moved house then
Users browsing this forum: Google [Bot] and 507 guests
