Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
tmb99
Joined: Tue Mar 09, 2010 10:30 pm Posts: 330 Location: Brisvages
 Posted: Wed Dec 22, 2010 3:20 am |
Got a steering box here that apparently is good, oily, but then all of the 3 I have are oily. However it has a bolt on the top where the others don't? I think this one may be off a NT whereas my others are WT, or has someone tapped a bolt in there for some reason?
If it is off a NT will that be ok on a WT?
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
Vehicle: 03 Jimny
 Posted: Wed Dec 22, 2010 3:27 am |
it will work on a wt and its juust a plug to top up the steering box im guessing
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Wed Dec 22, 2010 5:28 am |
That's the breather..
_________________ I used to be indecisive,
tmb99
 Posted: Wed Dec 22, 2010 7:29 am |
thanks for the clarification. I went and pulled the boxes apart, cleaned and changed the oil. Couple more questions...
The breather bolt was half way out, which is where it first starts to tighten up - should I tightened it right down?
The oil level went up and down as the box was turned, so I'm guessing the oil fill level should be just below its highest point?
I've filled it with diff oil and about 50% morey's oil stabiliser to thicken it up, that sound all right?
steak_knife
 Posted: Wed Dec 22, 2010 7:46 am |
I would of used grease, molly or graphite, but what you put in should be fine..
bazook
Joined: Sat Jul 12, 2008 11:30 pm Posts: 1082 Location: brisbane logan
 Posted: Thu Dec 23, 2010 7:48 am |
I've used diff oil before
_________________ josh AKA Bazook
steak_knife
 Posted: Thu Dec 23, 2010 8:13 am |
bazook wrote: I've used diff oil before
Should of used it in you diff to..
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 108 guests
