It is currently Mon Nov 02, 2026 5:58 am
Post Posted: Thu Dec 23, 2010 4:36 am
hey guys jus wondering, is the rear drive shaft suppose to have any play in the axel. :?
i can turn 1/8th of a turn before the axel engages. the driveline specialist put my locker in so i wouldnt have thought it would be that.
thanks
Post Posted: Thu Dec 23, 2010 4:43 am
im asuming you mean diff rather than axle.
there should be a small amount on play. (the proper term is back lash)
an 8th of a turn sounds like a lot
Post Posted: Thu Dec 23, 2010 4:45 am
I have about the same amount on both my diffs. I will be pulling them out to check the backlash as I too thing its too much.
Post Posted: Thu Dec 23, 2010 4:47 am
i would say half that would be good?
Post Posted: Thu Dec 23, 2010 4:52 am
Haha mine has close to a 1/4 of a turn before it engages :lol:
Post Posted: Thu Dec 23, 2010 5:37 am
auto lockers can cause an increase in backlash,
enough to fail some rwc inspections.
Post Posted: Thu Dec 23, 2010 5:38 am
would this cause the villant vibration at speed? and is it adjustable?
the driveline specialsist are the only ppl who touched it so shouldn't be that bad.
Post Posted: Thu Dec 23, 2010 5:44 am
I only notice the back lash when first starting off,
that is a bit of slack and sometimes a small clunk before drive.
Not noticed any other issues.
Never assume an expert hasn't made a mistake.
Specialists are human, too {just :) }
Vibrations can have many causes, uni joints,
tailshaft dents,wheel bearings, diff bearings,
mud stuck to wheel rims, so can be hard to find.
Post Posted: Thu Dec 23, 2010 5:47 am
Back lash of diff is adjustable, but slack in auto locker is in the design
Post Posted: Thu Dec 23, 2010 6:22 am
ok was hoping that
at first the vibration came at high speed but when i took accelerater of it stoped completly and wheel and inner bearings are new, so cant be wheels as well.
i fixed the uni's and the vib is only at high speeds now but noe still there when accelerater is off.
Post Posted: Thu Dec 23, 2010 6:26 am
try engine mounts, they can break and/or stretch without looking so.
vibrations change with engine movement
Post Posted: Thu Dec 23, 2010 6:47 am
hmmm ok good idea. ill have a drive later see if anything's different
Users browsing this forum: No registered users and 94 guests
