| 1.6 swift TBI FSM issues.... new pic's! https://auszookers.com/forum/viewtopic.php?f=5&t=17903 |
| Author: | 31zook [ Sat Jan 01, 2011 3:39 am ] |
| Post subject: | 1.6 swift TBI FSM issues.... new pic's! |
i have managed to find a fsm for my G13A, but i need one for my 16V swift tbi setup.... i must have 10 google thumbs.....
| Author: | want33s [ Sat Jan 01, 2011 4:10 am ] |
| Post subject: | Re: 1.6 swift TBI FSM |
I have wiring diagrams but no FSM. PM me your email if you want them.... |
| Author: | 31zook [ Sat Jan 01, 2011 5:02 am ] |
thanks jas |
| Author: | 31zook [ Tue Feb 15, 2011 7:44 am ] |
Ok, i need more help, layton came over and was working away till the pin out count was wrong on the ecu and the diargam we have isn't right, either of the two i have are right.... H5 1.6 SP A, is written on the ecu... any ideas, i believe it came from a 1.6 16V swift sedan... if layton want to put pic's up that he took then thats more then welcome.. it has more wires coming out of it then either of the two diagrams i have, non of the colours match up and im pretty sure it's from an auto swift.... really not sure what to do, if someone can help provide a pin out with more wires then below i would be more then greatful
with the right diagram i can wheel again, and i need to |
| Author: | 31zook [ Tue Feb 15, 2011 9:10 am ] |
| Post subject: | Re: 1.6 swift TBI FSM 16v special issue for me... |
shameless bump...... |
| Author: | JrZook [ Tue Feb 15, 2011 10:25 am ] |
Pic of the plug from teh ECU you have? |
| Author: | 31zook [ Tue Feb 15, 2011 4:49 pm ] |
ok, this arvo |
| Author: | LAY80N [ Wed Feb 16, 2011 2:05 am ] |
From memory it is a pin plug ECU loom - 28 and 16 pin (i only looked a this a few days ago, fark my memory is bad). Layto.... |
| Author: | JrZook [ Wed Feb 16, 2011 7:51 am ] |
LAY80N wrote: From memory it is a pin plug ECU loom - 28 and 16 pin (i only looked a this a few days ago, fark my memory is bad).
Layto.... Well I got a mitsu TBI ECU here on my desk that has a 16&24 pin plug.. Where did you get that ecu pinout from? Maybe its a US 1.3TBI one? |
| Author: | 31zook [ Wed Feb 16, 2011 8:34 am ] |
the guy i bought it off said that it was a G16ba..... and he did a really good job labeling everthing and being thorough..... will get a pic tomorrow hopefully..... and he sent that pin out along with the TBI, and jas (want33s) even sent me the same one... |
| Author: | boostedbrick [ Wed Feb 16, 2011 9:16 am ] |
I found a FSM for a SF416 some time last year, whice is what that ecu is out of i belive. It was on one of the torrent websites.. Mite be worth trawling them, i just had a quick look but couldnt see it. |
| Author: | gusbus [ Wed Feb 16, 2011 9:32 am ] |
i have tbi off mid 90's? cultus, 16 valve 1.3 ecu is 16 and 26 pin(not all used) and its marked G6 1.3-MT-002 |
| Author: | 31zook [ Wed Feb 16, 2011 10:45 am ] |
boostedbrick wrote: I found a FSM for a SF416 some time last year, whice is what that ecu is out of i belive. It was on one of the torrent websites.. Mite be worth trawling them, i just had a quick look but couldnt see it.
all the SF416 seems to be MPFI 1.3.............. |
| Author: | skyman [ Wed Feb 16, 2011 12:51 pm ] |
If you know the year, and engine model# the ecu came from. I can find the schematic. |
| Author: | 31zook [ Wed Feb 16, 2011 8:10 pm ] |
there is a slightly legable vin number in there.... im not sure if that helps.... the other plates are in the other photo, but i can't make anything out on them.....
even if someone can identify the car more clearly...... |
| Author: | 31zook [ Fri Feb 25, 2011 6:17 am ] |
JrZook wrote: Pic of the plug from teh ECU you have?
not sure if i have captured what you asked for
say 26 below
| Author: | joeblow [ Fri Feb 25, 2011 11:44 am ] |
| Post subject: | Re: 1.6 swift TBI FSM issues.... new pic's! |
there are 2 types of ecu for that efi system, you have the grey plug version and there is also a yellow plug version, both do the same thing but have completely different pin arrangments. |
| Author: | 31zook [ Fri Feb 25, 2011 6:28 pm ] |
Thanks Joe, do you have the pin out for the grey plug setup? |
| Author: | MART [ Fri Feb 25, 2011 10:18 pm ] |
90 model auto swift , Cheers Paul.
| Author: | 31zook [ Sat Feb 26, 2011 1:15 am ] |
awesome, i checked it with a few of my photo's and it matches up, thanks heaps paul thread over |
| Author: | JrZook [ Sat Feb 26, 2011 6:05 am ] |
Got it running yet? |
| Author: | 31zook [ Sat Feb 26, 2011 7:50 am ] |
layton need to reply to messages........... then ill get a better idea.... But when it is running ill be enjoying lifted Tcase, power steering and injection.... the truth is ill prob's hear it run, drive to weaves, get a power steering belt or two, drive it home, cut the floor out of it, lift the tank, cut the front guards to suit my wheel spacers..... there is one more big change to come, but thats along way off.... |
| Author: | LAY80N [ Sat Feb 26, 2011 1:46 pm ] |
Paul, your a champion. I will message you Josh and get up there to finish the wiring off Layto.... |
| Author: | 31zook [ Sat Feb 26, 2011 1:56 pm ] |
yay |
| Author: | shane1992 [ Sat Feb 26, 2011 3:47 pm ] |
LAY80N wrote: Paul, your a champion. I will message you Josh and get up there to finish the wiring off
Layto.... wire my 16L heheheheh |
