It is currently Mon Nov 02, 2026 8:20 pm
Post Posted: Sat Jan 01, 2011 9:15 am
does any one know if there is a off the shelf bumpstop that is about 25mm in the front and 30 - 40 mm in the rear bigger than stock that will fit a lwb 95 vitara?
the 31's are going on and thought i'd see if there is any instead of putting a spacer in there
Post Posted: Sat Jan 01, 2011 9:17 am
arb do a 25mm (I think) front spacer for the XL7, which should fit a vit front and rear
on the back I used some rhs cut with a holesaw to slide inside the spring and bolted the bumpstop to it and it to the bumpstop
Post Posted: Sat Jan 01, 2011 9:18 am
there is an OME bumpstop, not sure on the length.
ARB part #FK28, most ARB stores have no idea ARB/OME make it.
http://auszookers.com/index.php?name=Fo ... y+bumpstop
Post Posted: Sat Jan 01, 2011 10:29 am
http://www.bits4vits.co.uk/store/VITARA ... d_118.html
http://www.bits4vits.co.uk/store/VITARA ... od_35.html
Post Posted: Sun Jan 02, 2011 3:08 am
i'm more after a replacement bumpstop than spacers. i'll go check out the arb one this week some time
Post Posted: Sun Jan 02, 2011 7:40 pm
Abt do some nice ones but I'm not sure if the thread is right
Might have to weld a new nut on and drill out the old one
Post Posted: Mon Jan 03, 2011 10:07 am
If you can find an ARB stockist who will 1) admit that they exist and 2) agree to order some in for you grab a pair for me too.
Users browsing this forum: Google [Bot] and 103 guests
