It is currently Tue Nov 03, 2026 2:10 pm
Post Posted: Tue Dec 28, 2010 9:11 am
hi just wondering if any one could help me out with the wiring for a g13b mk3 into my 1989 siera please. mainly just ecu side of things i have a complete harness and standard ecu.
Vehicle: I drive your mum
Post Posted: Tue Dec 28, 2010 11:04 am
What specifically are you stuck on? Basically to wire a motor into a car, you need the wiring diagrams for both cars. Essentially the easiest way is to strip the new harness down to just what the motor needs to run, the connect the relevant power wires fro mteh new harness to the existing harness from teh old motor. To work out whats what you use the diagrams.
Thats a very basic explenation. Im just south of Newcastle, if you need a hand i might be able to help out.
Layto....
Post Posted: Thu Dec 30, 2010 1:51 am
iv got everyting together except iv got no injector pulse and cant work out y....
Post Posted: Thu Dec 30, 2010 1:52 am
is your fuel pump wired though you computer? i had that issue!
Post Posted: Sat Jan 01, 2011 8:05 am
Yer it's wired up threw the fuel pump relay...
Post Posted: Sun Jan 02, 2011 11:07 am
One of the reasons I got out of mechanics is all the electronic / antipollution / computer baggage. Bring back the days when a wire from the battery to the coil would get ya going. :D
Post Posted: Mon Jan 03, 2011 4:44 am
Wiring up motors isnt that hard You just need to figure out what provides the pulse to the injectors and trace the fault in that. Usually the crank angle sensor provides the ecu with cranking/rotating speed which it uses to trigger the injectors. I would start there. If you are still having troubles i can offer a bit of a hand later on in the week. PM me if your keen.
Layto....
Users browsing this forum: No registered users and 517 guests
