It is currently Mon Nov 02, 2026 8:20 pm
Post Posted: Sun Jan 02, 2011 10:36 am
How big are they width and height in inches?
Post Posted: Sun Jan 02, 2011 10:39 am
About 32" rolling diameter
Search! 30.7x9.5 http://www.4lo.com/calc/gearmetric.htm
Post Posted: Sun Jan 02, 2011 10:41 am
I have searched but because only have a phone where I am it's a bit hard thanks for the quick replys :-)
Post Posted: Sun Jan 02, 2011 10:42 am
copy & paste fail..... 31.7x9.3
^^^Prick.....Kinda close to a 31x10
Post Posted: Sun Jan 02, 2011 10:44 am
they sound like a nice shape/size tyre... tall/skinny
Post Posted: Sun Jan 02, 2011 10:49 am
They are. I have some for my trailer :wink:
Post Posted: Sun Jan 02, 2011 10:50 am
oops. I failed!!!1!
:oops:
But show me a tyre that is their real size..
Vehicle: SJ51T
Post Posted: Sun Jan 02, 2011 7:53 pm
i have some sitting in my garage waiting to go on.
i noticed that the tread width on them are more like 205-210, but the side wall sticks out a fair bit.
Post Posted: Sun Jan 02, 2011 8:14 pm
32" just measured one
Post Posted: Sun Jan 02, 2011 8:33 pm
I like them because on road they push the vehicle around less than a 10.5 tyre does, but they are still tall enough to give you some decent clearance.
Being an 85 profile means you probably get some sidewall flex in the corners :lol: but it doesn't seem to be as bad as I thought it would be.
Post Posted: Sun Jan 02, 2011 8:39 pm
ive thought about them before but what put me off is the amount of belts they run and the massive load rating most 235 85 16's have.
i wonder how they would go aired down??
Post Posted: Sun Jan 02, 2011 8:56 pm
I had the same reservations, and the belts might help keep them upright on the road. I haven't run much less that 15psi in these yet, I suspect I will have to drop a bit more air out of them than I would normally.
Post Posted: Sun Jan 02, 2011 9:05 pm
They are too tall to fit under a GV without lots of cutting and bashing of the guards.
I use this to do tyre comparo's. simple and easy
http://www.exploroz.com/Vehicle/Tyres/SizeCalc.aspx
the other one is this. it shows the difference and can help with imperial conversions.
http://www.miata.net/garage/tirecalc.html
Post Posted: Sun Jan 02, 2011 9:17 pm
Mine are on 16x7 rims. Measured height is about 31.5
Sidewall to sidewall measures about 9", tread with is closer to 7"
Post Posted: Sun Jan 02, 2011 9:20 pm
Thanks for the replys guys I'll be grabbing some of these for my vitara
Post Posted: Sun Jan 02, 2011 9:23 pm
Bodysaw FTW Armsup
Post Posted: Sun Jan 02, 2011 9:26 pm
Damo, i think you tape measure is broke.... they look like 30.5's
Post Posted: Sun Jan 02, 2011 9:30 pm
I'll check when I can be arsed going back out to the carpark
Post Posted: Sun Jan 02, 2011 9:38 pm
I'm with gus, but can I borrow you tape measure , want to measure my p...... 8O positive camber...
Vehicle: SJ51T
Post Posted: Sun Jan 02, 2011 11:25 pm
mine measure 30.5
im unsure of th rim width. i'd hazard a guess as being 7 or 8 wide
Post Posted: Mon Jan 03, 2011 12:04 am
the road grippers on my trailer measure 31 and 3/4 with 45 psi
Post Posted: Mon Jan 03, 2011 12:05 am
Are they 235/85R16 or 7.50R16?
Post Posted: Mon Jan 03, 2011 12:18 am
235's
Post Posted: Mon Jan 03, 2011 6:49 am
Tyres are also measured when they do not have the weight of the vehicle on them. so they will be bigger than what DAMO measured. calculator puts them at 31.7 inches tall.
Post Posted: Mon Jan 03, 2011 7:29 am
that was measured with 'em on the zook. The difference might be just down to brand. Mine are Federal Couragia MT
Users browsing this forum: Google [Bot] and 108 guests
