It is currently Mon Nov 02, 2026 8:20 pm
Post Posted: Sun Jan 09, 2011 8:57 pm
Replacing the rear wheel bearings on my sierra and the seal sits behind a retainer. Does the retainer come out? :)
Post Posted: Sun Jan 09, 2011 9:00 pm
I though the seal was infront of the seal saver? :?
Post Posted: Sun Jan 09, 2011 9:20 pm
There is a steel retaining ring that the seal sits behind. Reason why I want to know is cos the old seal was stuck to it so I need to clean the old rubber off.
Post Posted: Sun Jan 09, 2011 9:41 pm
Seal and seal saver..
Bearing and bearing retainer
Post Posted: Sun Jan 09, 2011 9:45 pm
Can ya get a picture without the seal in there?
Post Posted: Sun Jan 09, 2011 9:49 pm
Sorry mate its all back together now.
But the only thing behind the seal is the plastic seal saver. :?
Can you get a pic of what you are dealing with?
Post Posted: Sun Jan 09, 2011 11:04 pm
I think the steel bit might have been part of the old seal. Is that possible?
Post Posted: Sun Jan 09, 2011 11:28 pm
Yes. Some seals have a steel outer band.
So you think the rubber seal has separated from its steel outer?
If this is the case you must remove that steel band before fitting a new seal.
Any chance of a pic?
Post Posted: Mon Jan 10, 2011 4:24 am
All sorted. It was just part of the old seal :) :roll:
Users browsing this forum: Google [Bot] and 103 guests
