It is currently Mon Nov 02, 2026 8:20 pm
Post Posted: Wed Jan 12, 2011 4:46 am
ok so my shackles all round are very vertical, so what i was thinking for the front was to get the main and second leaf from some stock rears and use them to replace the ones on my front packs. i know it will move the diff forward and i already have a spacer.
my question is will he be possible and would i lose hight at all?
i did see a post before but couldn't re find it. it didnt really answer the question any way.
thanks
Post Posted: Wed Jan 12, 2011 5:32 am
That de[ends largely on the condition of your springs. But I would imagine you will lose some height due to the shackle angle becoming closer to horizontal.
Its only a couple hours work. Give it a go.
Also watch your brake lines and shock length and position under flex.
Post Posted: Wed Jan 12, 2011 5:38 am
i have long shocks, if it works the way id like it to ill put longer brake lines on. or should i get lifted rears ?
Post Posted: Wed Jan 12, 2011 5:41 am
I have always used lifted rears on mine and had good results, but I have done small chassis extensions at the same time.
Post Posted: Wed Jan 12, 2011 5:47 am
is it possible to jus put the on with out any modes, im on a budget hense the standard leafs idea.
Post Posted: Wed Jan 12, 2011 5:54 am
Search RUF. There are a few good thread in the 'rigs' section on the mod. It can most certainly be done on a budget, but its a very hands-on mod.
Post Posted: Wed Jan 12, 2011 5:59 am
cheers fatzook.
Post Posted: Wed Jan 12, 2011 6:05 am
sbbunno wrote:
cheers fatzook.
Yeah sorry. I'd find them for you, but I CBF :lol:
Post Posted: Wed Jan 12, 2011 6:17 am
all good still readin up
i thought it'd be possible for them to go straight on and just use a spacer. thats all it looks to me, also extended shackles to reach
Post Posted: Wed Jan 12, 2011 6:29 am
If you re-drill the fixed spring hanger you should be able to get away with just extended shackles, but that depends on the legth of the spring and how flat it sits.
Can you hold it up under the car next to the current spring and see how much farther forward the shackle eye sits?
Post Posted: Wed Jan 12, 2011 6:43 am
i havent orded anything yet as i dont wont to get into it untill i know for certain it will work.
Users browsing this forum: Google [Bot] and 108 guests
