It is currently Tue Nov 03, 2026 2:24 pm
Post Posted: Sat Jan 15, 2011 10:37 am
Just wondering are GV and XL7 struts the same? Are the XL7 struts longer than a GV Strut? and will the XL7 strut replace a GV one?
If they are the same does anyone know the part numbers for some lifted GV Struts?
Thanx
Post Posted: Sat Jan 15, 2011 1:05 pm
I can't tell you what the physical differences are, but the part numbers are different.
Post Posted: Sat Jan 15, 2011 1:24 pm
Would it be the vaulving of the struts?
Vehicle: Jeep
Post Posted: Sat Jan 15, 2011 2:59 pm
Thanx
The GV and XL7 both have the same struts, however, from what i understand, the XL7 has a higher capacity strut due to the XL7 being heavier, fyi, putting XL7 coils on a GV will give it a little lift and extra load capacity... :D
Post Posted: Sat Jan 15, 2011 9:16 pm
As above ^^^^ As far as I'm aware they are the same physical length and dimensions but the XL-7 ones are valved heavier due to the weight of the XL-7
Virgil the Vitara
SV620 Estate
Post Posted: Sun Jan 16, 2011 12:48 am
yeah they are the same length just harder valving
i run them on my vit to controll all the extra weight i have up front
( steel diff bull bar winch extra batt)
Post Posted: Sun Jan 16, 2011 12:55 am
OK then. thought they may have been longer.
Has anyone used the strut shaft extensions before? like these? http://www.bits4vits.co.uk/store/VITARA ... od_79.html
Post Posted: Mon Jan 17, 2011 2:21 am
^^^ No, but I have been using struts spacers for about 3 years with standard length struts and GV colis and had no problems. I thought the spacer looked a bit stronger than a screw on threaded piece?
Virgil the Vitara
SV620 Estate
Post Posted: Mon Jan 17, 2011 4:00 am
the other type of strut spacer dont fit on a GV properly as it messes up the strut brace.
Post Posted: Mon Jan 17, 2011 7:06 am
I have the ones from oda they are crap
They were just bare when I got them and they rusted into the top mount
Need to weld a big washer on the bottom to hold the boot down aswell
They would be good if some one made them proply
They need a hex milled in the side instead of cutting half the thread off
The nut can slip on the thread and it fucks them
Woulnt be hard tommake a set
Post Posted: Mon Jan 17, 2011 7:10 am
I think they are a shit idea, and just unsafe.
A strut top flip would be better. Or to go that step further, a new strut top that sits at the same height as a flipped OEM unit, but still allows the fitment of the GV strut brace.....
Post Posted: Mon Jan 17, 2011 9:02 am
Any chance something like this would appear in the 2001 TSOR catalogue to suit SV620 ??? :lol:
Virgil the Vitara
SV620 Estate
Post Posted: Mon Jan 17, 2011 9:20 am
Havent looked properly but i dont think a strut flip is possible in a GV due to the strut brace. But i could be wrong
Post Posted: Mon Jan 17, 2011 9:24 am
can't see why strut top spacers like the calmini ones wont work on a GV with a strut brace, a body lift will cause the strut brace to hit the inner guards.
Post Posted: Mon Jan 17, 2011 9:31 am
Yeah it can be done. But it requires some fabwork. Hence my suggestion of a bespoke unit.
Post Posted: Mon Jan 17, 2011 9:45 am
Not sure why you would lift the front end that much to require this mod when longer struts are available.
Strut doesnt sit on a level pane. so spacers will sit on the angle and not line up with brace.
Prob dont make sence till you have a close look . cutting the inner guard is not a big deal would only need to remove 20mm to have it clear the strut.
Post Posted: Mon Jan 17, 2011 9:49 am
How long? :roll: As with most suzukis, finding a quality strut that longer than 40mm over standard is quite hard.
Post Posted: Mon Jan 17, 2011 10:02 am
ironman, Dobinson, OME and i think Ridepro make 40mm longer struts and i found a site that uses a strut from another vehicle that can be made to fit.
http://tracker4x4.blogspot.com/2009/06/ ... truts.html
or Out door Auto sell struts that are75mm longer.
How much extra do you get from a strut flip?
Post Posted: Mon Jan 17, 2011 10:07 am
:roll:
Strut flip would give you 40-50mm I reckon.
Post Posted: Tue Jan 18, 2011 5:31 am
OK found out today that XL7 struts are suposed to be different but most strut makers only make one for both GV and XL7.
I did however discover that XL7 rear shocks are longer or are suposed to be.
Users browsing this forum: No registered users and 501 guests
