| GV / XL7 struts https://auszookers.com/forum/viewtopic.php?f=5&t=18273 |
| Author: | Built4thrashing [ Sat Jan 15, 2011 10:37 am ] |
| Post subject: | GV / XL7 struts |
Just wondering are GV and XL7 struts the same? Are the XL7 struts longer than a GV Strut? and will the XL7 strut replace a GV one? If they are the same does anyone know the part numbers for some lifted GV Struts? Thanx |
| Author: | fordem [ Sat Jan 15, 2011 1:05 pm ] |
| Post subject: | Re: GV / XL7 struts |
I can't tell you what the physical differences are, but the part numbers are different. |
| Author: | atari4x4 [ Sat Jan 15, 2011 1:24 pm ] |
Would it be the vaulving of the struts? |
| Author: | MacDaddy [ Sat Jan 15, 2011 2:59 pm ] |
Built4thrashing wrote: Just wondering are GV and XL7 struts the same? Are the XL7 struts longer than a GV Strut? and will the XL7 strut replace a GV one?
If they are the same does anyone know the part numbers for some lifted GV Struts? Thanx The GV and XL7 both have the same struts, however, from what i understand, the XL7 has a higher capacity strut due to the XL7 being heavier, fyi, putting XL7 coils on a GV will give it a little lift and extra load capacity... |
| Author: | Mick70b [ Sat Jan 15, 2011 9:16 pm ] |
As above ^^^^ As far as I'm aware they are the same physical length and dimensions but the XL-7 ones are valved heavier due to the weight of the XL-7 |
| Author: | got_bar_work [ Sun Jan 16, 2011 12:48 am ] |
yeah they are the same length just harder valving i run them on my vit to controll all the extra weight i have up front ( steel diff bull bar winch extra batt) |
| Author: | Built4thrashing [ Sun Jan 16, 2011 12:55 am ] |
OK then. thought they may have been longer. Has anyone used the strut shaft extensions before? like these? http://www.bits4vits.co.uk/store/VITARA ... od_79.html |
| Author: | Mick70b [ Mon Jan 17, 2011 2:21 am ] |
^^^ No, but I have been using struts spacers for about 3 years with standard length struts and GV colis and had no problems. I thought the spacer looked a bit stronger than a screw on threaded piece? |
| Author: | Built4thrashing [ Mon Jan 17, 2011 4:00 am ] |
the other type of strut spacer dont fit on a GV properly as it messes up the strut brace. |
| Author: | got_bar_work [ Mon Jan 17, 2011 7:06 am ] |
I have the ones from oda they are crap They were just bare when I got them and they rusted into the top mount Need to weld a big washer on the bottom to hold the boot down aswell They would be good if some one made them proply They need a hex milled in the side instead of cutting half the thread off The nut can slip on the thread and it fucks them Woulnt be hard tommake a set |
| Author: | Fatzook [ Mon Jan 17, 2011 7:10 am ] |
got_bar_work wrote: I have the ones from oda they are crap
They were just bare when I got them and they rusted into the top mount Need to weld a big washer on the bottom to hold the boot down aswell They would be good if some one made them proply They need a hex milled in the side instead of cutting half the thread off The nut can slip on the thread and it fucks them Woulnt be hard tommake a set I think they are a shit idea, and just unsafe. A strut top flip would be better. Or to go that step further, a new strut top that sits at the same height as a flipped OEM unit, but still allows the fitment of the GV strut brace..... |
| Author: | Mick70b [ Mon Jan 17, 2011 9:02 am ] |
Quote: A strut top flip would be better. Or to go that step further, a new strut top that sits at the same height as a flipped OEM unit
Any chance something like this would appear in the 2001 TSOR catalogue to suit SV620 ??? |
| Author: | Built4thrashing [ Mon Jan 17, 2011 9:20 am ] |
Fatzook wrote: A strut top flip would be better. Or to go that step further, a new strut top that sits at the same height as a flipped OEM unit, but still allows the fitment of the GV strut brace.....
Havent looked properly but i dont think a strut flip is possible in a GV due to the strut brace. But i could be wrong |
| Author: | atari4x4 [ Mon Jan 17, 2011 9:24 am ] |
can't see why strut top spacers like the calmini ones wont work on a GV with a strut brace, a body lift will cause the strut brace to hit the inner guards. |
| Author: | Fatzook [ Mon Jan 17, 2011 9:31 am ] |
Built4thrashing wrote: Fatzook wrote: A strut top flip would be better. Or to go that step further, a new strut top that sits at the same height as a flipped OEM unit, but still allows the fitment of the GV strut brace..... Havent looked properly but i dont think a strut flip is possible in a GV due to the strut brace. But i could be wrong Yeah it can be done. But it requires some fabwork. Hence my suggestion of a bespoke unit. |
| Author: | Built4thrashing [ Mon Jan 17, 2011 9:45 am ] |
Fatzook wrote: Built4thrashing wrote: Fatzook wrote: A strut top flip would be better. Or to go that step further, a new strut top that sits at the same height as a flipped OEM unit, but still allows the fitment of the GV strut brace..... Havent looked properly but i dont think a strut flip is possible in a GV due to the strut brace. But i could be wrong Yeah it can be done. But it requires some fabwork. Hence my suggestion of a bespoke unit. Not sure why you would lift the front end that much to require this mod when longer struts are available. atari4x4 wrote: can't see why strut top spacers like the calmini ones wont work on a GV with a strut brace, a body lift will cause the strut brace to hit the inner guards.
Strut doesnt sit on a level pane. so spacers will sit on the angle and not line up with brace. Prob dont make sence till you have a close look . cutting the inner guard is not a big deal would only need to remove 20mm to have it clear the strut. |
| Author: | Fatzook [ Mon Jan 17, 2011 9:49 am ] |
Built4thrashing wrote: Not sure why you would lift the front end that much to require this mod when longer struts are available.
How long? |
| Author: | Built4thrashing [ Mon Jan 17, 2011 10:02 am ] |
ironman, Dobinson, OME and i think Ridepro make 40mm longer struts and i found a site that uses a strut from another vehicle that can be made to fit. http://tracker4x4.blogspot.com/2009/06/ ... truts.html or Out door Auto sell struts that are75mm longer. How much extra do you get from a strut flip? |
| Author: | Fatzook [ Mon Jan 17, 2011 10:07 am ] |
Built4thrashing wrote: or Out door Auto sell struts that are75mm longer. How much extra do you get from a strut flip? Fatzook wrote: How long? Strut flip would give you 40-50mm I reckon. |
| Author: | Built4thrashing [ Tue Jan 18, 2011 5:31 am ] |
OK found out today that XL7 struts are suposed to be different but most strut makers only make one for both GV and XL7. I did however discover that XL7 rear shocks are longer or are suposed to be. |
