It is currently Tue Nov 03, 2026 6:22 am
Post Posted: Sat Jan 22, 2011 12:54 am
Hey guys I got a second hand set of 4wd free wheel hubs and I'm having a little trouble taking the old 1s off all the bots are off but the body just sits there and spins if any1 knows what I'm doing wrong please let me kno.
Post Posted: Sat Jan 22, 2011 1:01 am
There's a circlip inside that you have to remove.
Post Posted: Sat Jan 22, 2011 1:37 am
it is on the end of the axle :wink: i never bother to stick them back on.
dunno if that is good or bad but it makes taking the hub off a lot easier.
Post Posted: Sat Jan 22, 2011 1:41 am
I think the ring that's about 50 mm thick with the male groves is stuck inside
Post Posted: Sat Jan 22, 2011 1:50 am
thread one of the hub bolts into the end of the axle so you have something to grip
then pull the axle out a bit, it will only move a couple of mm but you should then be able to see the external circlip.
Post Posted: Sat Jan 22, 2011 2:19 am
Just tryed that but it doesn't move out getting pritty frustrating Iv taken 1 wheel off so it's just the hub body but can't pull it off it just spins really keen to swap these today so I can atleast drive I can't find the circlip any 1 got a YouTube link or diagram that would help?
Post Posted: Sat Jan 22, 2011 2:44 am
Can you post a pic of what you're dealing with?
Post Posted: Sat Jan 22, 2011 10:36 pm
go to tech sect there is a thread with swivel hub rebuild..got pics from start to finish ..you will see your circlip there .
Users browsing this forum: No registered users and 576 guests
