https://auszookers.com/forum/
Mill drill and keyless chuck
https://auszookers.com/forum/viewtopic.php?f=5&t=18311
Page 1 of 2
Author:  Damo [ Mon Jan 17, 2011 12:04 am ]
Post subject:  Mill drill and keyless chuck
I have a mill/drill which takes MT3 arbor. I have a 13mm Jacobs keyless chuck (decent one) which I put a holesaw arbor in as I was using a 54mm holesaw. So I drilled my holes no dramas, but when I came to undo the chuck, the bastard thing was TIGHT.
Short of going at it with multigrips :oops: how the hell do I get the bastard thing undone???? :x
Author:  royce [ Mon Jan 17, 2011 12:07 am ]
Post subject:  Re: Mill drill and keyless chuck
I remember learning how to do it at school, but it was a long time ago :), maybe punch it loose with a drift?
Author:  Damo [ Mon Jan 17, 2011 12:19 am ]
I can get the chuck out of the mill (give the drawbar a whack), i just cant undo the chuck so I can get the holesaw out.
Author:  eXc450 [ Mon Jan 17, 2011 12:30 am ]
if you can get the chuck off, can you use a vice + mutli grip/vice grip?
Author:  Damo [ Mon Jan 17, 2011 12:37 am ]
I could, but I don't want to mess up my chuck using multigrips on it!!!
Maybe some alloy or copper shim wrapped around it would protect it?
Author:  eXc450 [ Mon Jan 17, 2011 12:50 am ]
it's gonna look bad in 5 years time anyways... :p you could try a cloth... or search you tube....there are tips on ones with keys...couldnt see anything for keyless...bit of a silly idea IMO except on a hand drill
Author:  BlueSuzy [ Mon Jan 17, 2011 12:51 am ]
alloy or copper and vice/vicegrips/stilson/pipe jaws/hammer/bin
I HATE keyless chucks for that reason.
Author:  royce [ Mon Jan 17, 2011 12:51 am ]
oops I missed the keyless part, chisel into teh side :)
Author:  Damo [ Mon Jan 17, 2011 12:59 am ]
I have a feeling these chucks tighten as you use them, and the leverage a holesaw gives is why it is SO tight.
Oops :oops:
Author:  BlueSuzy [ Mon Jan 17, 2011 1:00 am ]
They only get worse as the get older too..
Author:  Damo [ Mon Jan 17, 2011 1:26 am ]
Did some more Googling, aparantly the way to go is hold it in a vice with soft jaws, then use a strap wrench to undo.
WTF is a strap wrench, yeah, I asked the same thing.
Will have a crack tonight, I think I have some aluminium scrap to use as soft jaws, i'll try to cobble together a strap wrench from old seatbelt material.
I hope it works coz that Jacobs chuck (precision model) won't be cheap to replace!
Author:  BlueSuzy [ Mon Jan 17, 2011 1:30 am ]
Bout $75
https://www.machineryhouse.com.au/Produ ... kCode=C289
Author:  ball [ Mon Jan 17, 2011 1:54 am ]
Try an oil filter strap if you have it.
A decent keyless chuck actually has a couple of holes that you can use a C spanner to tighten or loosen the thing.
Author:  Damo [ Mon Jan 17, 2011 2:00 am ]
I don't remember seeing c spanner holes but i'll have another look tonight.
I was pretty sure ball would post in here and was expecting the first words of balls post to be "you f*cking idiot" :lol:
Author:  ball [ Mon Jan 17, 2011 2:07 am ]
nope, I do that shit all the time. The difference is I know I have a spanner to undo the bastard. :wink:
I don't know how hard your chuck is but you may be able to drill some holes in the side like these ones.
Author:  stocker [ Mon Jan 17, 2011 5:43 am ]
D-Clamp? thats how i get holesaws out of the drill when they get stuck at work...
doesn't mess the chuck up either :)
Author:  Damo [ Mon Jan 17, 2011 5:46 am ]
What's a D-clamp? never come across one of them
Author:  stocker [ Mon Jan 17, 2011 5:49 am ]
Thats a d Clamp :)
Author:  appsie [ Mon Jan 17, 2011 5:54 am ]
G
Author:  Fluffy [ Mon Jan 17, 2011 6:22 am ]
dude dont use multi grips ..just a 3 inch g clamp.. a lot less brutal on the knurled surface . one of my fkn apprentices put a vice grip on mine.. i near killed him. and still might
Author:  Damo [ Mon Jan 17, 2011 6:27 am ]
Seems like this is a fairly common thing, I don't feel like such a dickhead now :lol:
Thanks for the tips guys.
Author:  stocker [ Mon Jan 17, 2011 6:37 am ]
ah my bad, g clamp :D ... its a fitting tool. im an electrician :D... forgive the stupidness we work with our hands in the air :D
Author:  TZAR [ Mon Jan 17, 2011 7:58 am ]
I destroyed one with a grinder to get a drill bit out.
$30 ozito drill that burnt out and had a good 12.5mm drill bit in it so I cut the thing open with a cut off wheel
Author:  TZAR [ Mon Jan 17, 2011 8:05 am ]
since you have a mill drill just machine some flats in it
Author:  kenn [ Mon Jan 17, 2011 8:33 am ]
Maybe some heat could help..
Author:  shep [ Mon Jan 17, 2011 8:40 am ]
flog it with a big hammer until it comes out.
Author:  kenn [ Mon Jan 17, 2011 8:51 am ]
Yeah that should generate some heat :lol:
Author:  Teracis [ Mon Jan 17, 2011 9:14 am ]
Was going to suggest the strap/strap wrench.
Author:  ball [ Mon Jan 17, 2011 9:18 am ]
Author:  Polar_Bear [ Mon Jan 17, 2011 10:31 am ]
i just use multi grips on mine at work, and put the drill in reverse... but i'm not overly attached to it :wink:
Page 1 of 2 All times are UTC + 9:30 hours
