It is currently Tue Nov 03, 2026 2:23 pm
Post Posted: Mon Jan 17, 2011 8:57 pm
hey guys tried doing a search and gathered lots of useful information, but am now stuck.. I am in the process of doing my front right wheel bearing on my wt sierra and i cant get the actual bearing out.. have taken the hub off completely and it wont come out
and tricks to getting it out?
Post Posted: Mon Jan 17, 2011 9:13 pm
Give it a smack with a hammer and punch, if that don't work, get a bigger hammer, don't matter if the bearing breaks, ur replacing it ne way
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Mon Jan 17, 2011 10:26 pm
i got the bearing out.. but now i cant get the metal bit that the bearing sits inside of out.. i cant smack it with a hammer because it is tapered in wards, so if i hit it in it gets tighter.. and i cant get to behind it.
what do i do now?
Post Posted: Mon Jan 17, 2011 10:35 pm
Hey bud, get the hub , sit it on a piece of wood, get a hammer and a long punch or flat blade screw driver,(preferably one you don t like as it may damage the tip, ) and put the punch inside the hub on the lip of the bearing runner and punch it out but remember to work aroud the runner so
you don't scar a lip inside the hub
Post Posted: Mon Jan 17, 2011 10:38 pm
is the runner the sleeve the bearing sits inside? Im not very good with the terms..
next.. once you get the front bearing out, is there another bearing behind that in the bottom? if so, does this need replacing? I have been given two bearings and told it will do one side.. if so, how do i get to the second bearing
Post Posted: Mon Jan 17, 2011 10:43 pm
here is where im up to
Post Posted: Mon Jan 17, 2011 11:12 pm
Yeah mate the sleve is the runner, same same, there is 2 bearings one either side of the hub , you'll heve to Nock out both bearing SLEVES out of the hub wack the new ones in and ur away"""
Post Posted: Mon Jan 17, 2011 11:21 pm
And remember to grease your bearings real well don't go shy on grease, grease is cheap, bearings and cv"s are not
Post Posted: Tue Jan 18, 2011 12:58 am
Get a press or take it to some one with one
I had a bearing rust in and it took a 50 t press to get the sleeves out
Post Posted: Tue Jan 18, 2011 9:58 am
okay got it all out in the end, took a lot of effort. used a press to get the inner bearing on, but does the outer bearing need to be pressed as well? i cant get the (chromo or cv - bar with knuckle on it) to come through the bearings far enough to attach sirclip..
is this sirclip necessary?
Post Posted: Tue Jan 18, 2011 10:14 am
can you pull/pry the axle out a bit? Or is it in there good and deep like?
Theres a bit of play with standard ones, sometimes have to pry them outwards so the circlip can be placed on.
Post Posted: Tue Jan 18, 2011 10:16 am
i pulled it as far as i could and was about a mm or two till the circlip slot coming forward.. do i have to do the nuts on the outside of the bearing until tight and then undo a few notches so the bearing is pressed in?
Users browsing this forum: No registered users and 514 guests
