| CARBON CANISTER HELPP https://auszookers.com/forum/viewtopic.php?f=5&t=18371 |
| Author: | zook95 [ Wed Jan 19, 2011 8:51 am ] |
| Post subject: | CARBON CANISTER HELPP |
hey guys can someone help me with my car it dies down to a stall at traffic lights how can i by pass my carbon canister please help its a 1992 sierra widetrack thanks luke |
| Author: | Teracis [ Wed Jan 19, 2011 9:08 am ] |
| Post subject: | Re: CARBON CANISTER HELPP |
??? Is there some underlying problem? EDIT: Turns out carbon canister is a fuel line thing |
| Author: | EldarO [ Wed Jan 19, 2011 9:13 am ] |
your carbon canister is supposed to be connected, fix the underlying issue. |
| Author: | Taylor74 [ Wed Jan 19, 2011 9:18 am ] |
Carbon canister is soposed to purget the fuel tank, Removing it is silly and Illegal. You do have it connected to the correct port on the carb? |
| Author: | zook95 [ Wed Jan 19, 2011 9:55 am ] |
my problem comes and goes for instant today coming home from work it was a piece of SH!@ but then when i got home to get the tools out it was running perfect |
| Author: | MrRocky [ Wed Jan 19, 2011 10:09 am ] |
replace canister or blow out all lines to the tank with high pressure air mine filled up with mud and after a blow out was fine. could be blocked idle jet, stuffed fuel pump, rooted carb ect... |
| Author: | zook95 [ Wed Jan 19, 2011 10:15 am ] |
my carby just had a kit throught it aswell |
| Author: | paulv [ Wed Jan 19, 2011 11:37 am ] |
Have you checked the basics? Fuel pump pressure? Idle mixture Adjustment? Anti Dieseling solenoid connected correctly and functioning? Wax pellet on the carb opens the choke and closes the choke completely? Base ignition timming? |
| Author: | EldarO [ Wed Jan 19, 2011 2:33 pm ] |
who did the carby kit? if it was a DIY job, ive only ever had half the carbs ive redone myself fixed, can never seem to clean them as well as the carb specialists can |
| Author: | zook95 [ Wed Jan 19, 2011 11:01 pm ] |
a mechanic shop did the kit |
| Author: | shep [ Wed Jan 19, 2011 11:15 pm ] |
i threw my canister away years ago with no adverse running issues. |
| Author: | christover1 [ Thu Jan 20, 2011 3:14 am ] |
After 3 failed cannisters I threw it away, but you must still have a clear vent line connected, Or you can get vapour lock issues, and collapsed tank. I ran a line up the back of ute cab, with a fuel filter on it. This is not legal, and fuel loss i9s possible in rollovers. But car ran better ever after. Check for blockages, cannisters do need replacing frequently. Mine wasn't venting, and parking in sun caused fuel to leak out thru carby..took some trouble shooting to figure it out |
