It is currently Thu Nov 05, 2026 9:12 am
Post Posted: Thu Feb 10, 2011 11:54 am
Ive always known that the VVT Jimny gearboxes were weak But in the last 6 months have had 3 fail. Yesterday removed a box from a customers car that had done 42000km 3 months out of waranty to replace bearings as it had done the usual failer rear countershaft bearing.
Every gear in the box the case hardening had worn through.
So removed a gearbox from a rollover wreck that had done 50000kms and poped it apart to check it to find the bearings had not failed yet but the case hardening had started to fail on all the gears aswell.
Now we are rebuilding the origional box.
My suggestion is perhaps synthetic oil to reduce wear as every gear and shaft in the box isn't cheap. Any one else seen this ?
Suzuki is my way of life.
Post Posted: Thu Feb 10, 2011 12:04 pm
I think zukenuter has had one fail.... :?
Post Posted: Thu Feb 10, 2011 12:30 pm
taylor74 - working for who you do, can you ask suzuki australia about this? perhaps its a manufacturing defect? Maybe maruti made them? lol
Post Posted: Thu Feb 10, 2011 12:36 pm
You know who alien and your free to say. Im sure Suzuki Aus do know about it As all the parts to replace the gearbox are readily avaliable in Aus, That must say something.
Post Posted: Thu Feb 10, 2011 12:57 pm
ha my jim is a non-vvt Armsup
hope this issue is only vvt's and nto the previous models :?
he runs an auto box :wink:
Post Posted: Thu Feb 10, 2011 1:03 pm
In both his jimnies? I thought they were manuals too.
Post Posted: Thu Feb 10, 2011 9:52 pm
VVT gearboxes are one to themself they are 1 to 1 in 5th gear where as the non VVT boxes are the same as a sierra(have overdrive). The VVT box weighs alot less than the other aswell. They are a real bacward box where the input shaft is the main shaft and the out put is only short. You can not even put an early style box in them as the chassie is different along with the diffratios are much higher alowing 5th gear being at the 1 to 1 ratio. The centre shaft has a different spline count and shorter making them VVT only
Vehicle: 07 vvt jimny
Post Posted: Wed Feb 16, 2011 7:31 am
ohhh noo :O we have been having problems with our gear box selecting reverse and alot of the other gears can be hard to select they go in but require effort of another pump of the clutch untill its warmed up. might changed out the oil that the old mechanic had used.
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Wed Feb 16, 2011 7:43 am
Post Posted: Wed Feb 16, 2011 8:08 am
are you laughing at spelling stekky? or helping me out lol im sure its cause how he spelt chassis?
sorry CHOP :P
Post Posted: Wed Feb 16, 2011 8:24 am
That's not even your post I quoted..
It's not even a laughing emo con.
Confused, because I have never seen different chassis's between the Vvt & non Vvt Jim's........ " :? "
I can't see Suzuki making an entirely different chassis for a eng that is the same bar a cam pulley & an oil control valve..
Post Posted: Wed Feb 16, 2011 9:08 am
Give me a break im a thats why I became a mechanic (not good at spelling lol)
If you stick your head under a VVT version the gearbox mount is behind the cross member, Non VVT the mount is welded infront of the member make it a bucket load easier to get the box out on the VVT.
I only found out because was going to try a non VVT box int it but it fell short of the cross member
Post Posted: Wed Feb 16, 2011 9:13 am
My spelling's not much chop either mate... :lol:
You still have the car at work?? Can yo please take some pic's for me??
I can't remember there being a difference in the chassis.......
Oh, shit g/box's isn't just the Vvt's, any M engined jim's suffer from shit box's...
Post Posted: Wed Feb 16, 2011 9:25 am
I also i have trouble getting into reverse and as zuk85 said have to pump the clutch a few time's before it goes in and also have a bit of trouble with first, it has been like this from day one.
Vehicle: Suzuki Grand Vitara
Post Posted: Wed Feb 16, 2011 9:50 am
That is just a Suzuki thing.
Both my Vit's and Baleno are the same.
Post Posted: Wed Feb 16, 2011 9:58 am
Ok i can sleep tonite now.
Post Posted: Wed Feb 16, 2011 10:01 am
change your oil to Vmx80, problem solved...
Post Posted: Wed Feb 16, 2011 10:20 am
mine still is a biatch to select first when its hot. even with fresh vmx 80 in it.
Post Posted: Wed Feb 16, 2011 10:22 am
Both my vit boxes are fine. Perhaps you need to run a better oil....
Post Posted: Wed Feb 16, 2011 10:24 am
yeah same prob here... I have to either select other gear, double clutch, kinda move the car backwards :?
problem fade away for a few days after I did the mayor service to the car and the oil got change, but now is tha same that bfore..... I would try that next time :wink:
but its good to know its a regular thing and not only me..... it just scare me it wont engage quick enough to reverse a hill if I fail climb it :?
Mine will be going in for it's 12month service next month.
Post Posted: Wed Feb 16, 2011 10:30 am
Tell em to change the box oil to Vmx80, other wise it won't get done till 45k..
Post Posted: Wed Feb 16, 2011 10:33 am
Ok thanks i will do that.
Post Posted: Wed Feb 16, 2011 11:07 am
+7
Post Posted: Thu Feb 17, 2011 9:34 pm
vmx80 here i come :D:D
sorry CHOP :P
Post Posted: Fri Feb 18, 2011 6:40 am
You got me worried now. I'm off to Moreton Island in a couple of months and the Jimny has done 90000kms. I'm about to get it serviced, is there any precaution or checks that can be done before it fails?
Vehicle: Jeep
Post Posted: Fri Mar 11, 2011 5:47 pm
Taylor74 wrote:
You know who alien and your free to say...
And i now know who as well... he he... good to see you here... i think you could be a great asset to the Suzi Talk and Tech sections :wink: :lol:
Post Posted: Fri Mar 11, 2011 6:45 pm
G/box oil is due every 45k, so should be changed at 90k..
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 42 guests
