It is currently Mon Nov 02, 2026 9:20 pm
Poll: Can this conversion be done for $1500 or less?
Yes 67%  67%  [ 4 ]
No 33%  33%  [ 2 ]
Total votes : 6
Post Posted: Thu Jan 20, 2011 11:44 pm
well the zook I bought a few months back has a cracked head, and I'm tight on cash so trying to get a fairly accurate figure on what it would cost me to convert to a G16B engine. From searching around on the site, I figure this conversion should be cheaper then a standard G16B into a sierra since I've already got the EFI stuff. Just about every thread I read was tackling this conversion from a carby starting point, whereas I'm not, so what needs to be done and what are the costs?
Engine, ecu and loom - $800?
BenT adapter $200
speedo cluster for dash ?
I've heard the starter motor can be modified to fit
Can use current air filter apparently
I have a 3 core HD radiator which I can use
Can do wiring myself
Sump needs to be modified, but what actually needs to be done?
What costs am I missing?
Is it possible to do this for around $1500?
Post Posted: Fri Jan 21, 2011 12:08 am
the 1.6 16 valve and G13bb heads are the same, so makes sense to find an engine and head and use the jimny manifolds and ecu then have it dynoed to see what the mixtures are doing
Vehicle: Zookless
Post Posted: Fri Jan 21, 2011 1:04 am
Shift wrote:
Engine, ecu and loom - $800? I paid $900 for a '00 Baleno engine with 25K on it, including ECU, wiring loom, cluster, and shipping to Tassie.
BenT adapter $200 Yep
speedo cluster for dash ? Cheap from wreckers, make your own VSS.
I've heard the starter motor can be modified to fit with a grinder.
Can use current air filter apparently Yes
Sump needs to be modified, but what actually needs to be done? See this thread. It only needs to be modified if using a Baleno sump with crank angle sensor.
What costs am I missing? Engineering or compliance plate?
Is it possible to do this for around $1500? Easy, if you do it all yourself.
Users browsing this forum: Google [Bot] and 437 guests
