[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
mighty_vites
Joined: Fri Oct 01, 2010 6:41 am Posts: 218 Location: Mackay
Vehicle: SV420 SE416SWB SE416LWB SIERRA
 Posted: Fri Jan 21, 2011 1:07 am |
Im in the process of replacing my carby and have hit a few snags along the way. Keep in mind that i am not 100% competent with them as all my other cars have been EFI and the carb on my motorbike has never had an issue.
It is a stock carby just a little tweaked (purchased off 31zook, thanks mate)
1. Idle is around 1500-2500 and varies every time i start it up.
2. Previous carb was removed by my brother for me while i was away (appreciate his help but didnt label any hoses for me) so im stabbing in the dark as to what goes where. pictures would be very helpful if anyone has any
3. Choke plate seems to stay open as if there is not enough spring tension, is this a vacuum or mechanical thing?
thank you in advance to anyone with helpful advice.
mighty_vites
 Posted: Fri Jan 21, 2011 1:31 am |
is this relevant to what im trying to achieve?
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Fri Jan 21, 2011 2:24 am |
have you let it run for a while for the rev's to come down? when i had it on mine it rev'd at 1100rpm once warmed up....
mighty_vites
 Posted: Fri Jan 21, 2011 2:46 am |
yer its sat running for a while, its the vacuum hosing thats doing my head in more than anything. i figure once they are in correct positions it should run well
correct?
gympzook
Joined: Fri Oct 22, 2010 6:39 am Posts: 46 Location: Gympie
Vehicle: 1986 Sierra SJ50
 Posted: Fri Jan 21, 2011 4:34 am |
I had the same problem, plus had run-on problems. After bashing my head against a brick wall for a few weeks trying to get the carby sorted, wasting a heap of time and money, I gave up and took the car to carby people, we stuck in a webber with a cutoff solenoid and electric choke, tuned it up with the best jets for the engine. Car now idles at 700 to 800, purrs like a kitten, gets 30% better fuel economy, and goes like a rocket. Its a frustrating path you're going down, good luck if you persist with the stock carby!
[ 5 posts ] |
Users browsing this forum: No registered users and 496 guests
