| Swaybar https://auszookers.com/forum/viewtopic.php?f=5&t=18485 |
| Author: | Bennyzarb [ Sun Jan 23, 2011 6:26 pm ] |
| Post subject: | Swaybar |
What does tacking out the sway bar do to your car does it still handell the same is it more prone to rolling Off road V's On road |
| Author: | fire60 [ Sun Jan 23, 2011 8:19 pm ] |
| Post subject: | Re: Swaybar |
I took mine out of 92 Vit 2dr about 18 mths ago. Much better off road, not much different on road. I won't be putting it back in. |
| Author: | BlueSuzy [ Sun Jan 23, 2011 8:53 pm ] |
Every sierra owner takes it off, then it never goes back on. Onroad not much different, offroad makes the front move more. |
| Author: | Bennyzarb [ Sun Jan 23, 2011 9:07 pm ] |
Ok I will take it off this arvo |
| Author: | Fatzook [ Sun Jan 23, 2011 9:13 pm ] |
I'm putting upgraded swaybars on my sierra I find that there is a noticable difference in body roll when the swaybar is removed on-road. And this will be amplified as you lift the vehicle. |
| Author: | matfan [ Sun Jan 23, 2011 9:41 pm ] |
Yeah piss it off. |
| Author: | JrZook [ Sun Jan 23, 2011 9:47 pm ] |
Fatzook wrote: I'm putting upgraded swaybars on my sierra
I find that there is a noticable difference in body roll when the swaybar is removed on-road. And this will be amplified as you lift the vehicle. x2! Significant difference in handling on road, especially when loaded! |
| Author: | suzi-fan-22 [ Sun Jan 23, 2011 9:50 pm ] |
Pics and description \ diagram of upgraded swaybar? |
| Author: | Fatzook [ Sun Jan 23, 2011 11:47 pm ] |
Off the shelf from Whiteline. |
| Author: | Brenno [ Mon Jan 24, 2011 2:23 am ] |
Fatzook wrote: Off the shelf from Whiteline.
Got a link - I couldnt find Sierra under makes on their website. Wouldnt mind upgraded front and rear swaybars... |
| Author: | Fatzook [ Mon Jan 24, 2011 6:53 am ] |
Brenno wrote: Fatzook wrote: Off the shelf from Whiteline. Got a link - I couldnt find Sierra under makes on their website. Wouldnt mind upgraded front and rear swaybars... I got my quote through Fulcrum. I hope they are still available |
| Author: | zukenutter [ Mon Jan 24, 2011 7:26 am ] |
JrZook wrote: Fatzook wrote: I'm putting upgraded swaybars on my sierra I find that there is a noticable difference in body roll when the swaybar is removed on-road. And this will be amplified as you lift the vehicle. x2! Significant difference in handling on road, especially when loaded! X3. Sierras are tolerable without it due to friction between the leaves. I find the jimny a lot more unruly. On the highway with lift and no sway can be a bit of a White knuckle affair. |
| Author: | christover1 [ Mon Jan 24, 2011 7:33 am ] |
I'm running no sway bar on my LWB Vitara. I can feel the difference. Heaps better off road, bit lioke a tug boat on road My shocks seem to be soft at low speed, and stiffer at high speeds. (or it could be my imagination) So i can cope with it. |
| Author: | MrRocky [ Mon Jan 24, 2011 8:16 am ] |
i have a soft 3 leaf ruf pack up front and find it an absolute pig in corners without it, so i run it during the week and take it of for weekend trips. |
