https://auszookers.com/forum/
jimny roof rails?
https://auszookers.com/forum/viewtopic.php?f=5&t=18532
Author:  Gizmo3332 [ Tue Jan 25, 2011 7:17 am ]
Post subject:  jimny roof rails?
hey guys,
i was just wondering how i fit the roof rails?
i brought them from the wreckers. they only came with 8 nuts. am i missing other parts that they haven't given me?
also there are no mounting points as such under the black strip on the roof.
any help is much appreciated
Dale
Author:  89_tintop [ Tue Jan 25, 2011 7:19 am ]
Post subject:  Re: jimny roof rails?
Pretty sure the bolt into the roof itself mate...
Author:  Gizmo3332 [ Tue Jan 25, 2011 7:22 am ]
so ive gotta drill the holes in the roof?
and they didnt come with bolts? just nuts.
Author:  BlueSuzy [ Tue Jan 25, 2011 7:25 am ]
The original JLX jimnys have studs coming out of the roof, welded in. Thats why you only have nuts.
They were not in the body/black strip seam either.
Author:  89_tintop [ Tue Jan 25, 2011 7:27 am ]
Not sure on the exact set up.
But am sure that they mount through the roof.. That i am certain of.
I would say you.may need to nutsert the roof itself (think that's what they are called)
if you don't mind me asking what did you pay for them
Author:  Gizmo3332 [ Tue Jan 25, 2011 7:39 am ]
well i only have the jx model, so having roof racks could be a problem.
hopefully i can work something out.
they were $132
Author:  zukenutter [ Tue Jan 25, 2011 7:50 am ]
I've seen ROLA racks on JX jimnys. Different to the ones for a JLX.
Author:  BlueSuzy [ Tue Jan 25, 2011 7:51 am ]
They were also studs so there is no holes in the roof to leak.
I would probably nutsert with a shitload of silastic to bolt on. Seal it right up. Don't want water coming in on a hardtop.
Author:  watermouse [ Tue Jan 25, 2011 9:15 pm ]
Definitely studs through roof.. see attached picture.
Author:  BAZZOOK [ Tue Jan 25, 2011 9:22 pm ]
rivets in mine
Author:  Benz [ Tue Jan 25, 2011 10:47 pm ]
I would try and take them back.
for the hassle and price tag! they aren't worth it.
the factory ones are crappy and plastic anyway and you still need to get cross bars. (I have broken a set already)
get a set like bazzok's. http://www.rhinorack.com.au/BarType_Spo ... 005_3.aspx
they are much stronger. sure you still need to drill holes in the roof... but you cant get away from that...
Author:  Gizmo3332 [ Wed Jan 26, 2011 6:43 am ]
thanks heaps for the pictures guys,
Bazzook did you fit your roof rack yourself? did it take much?
Author:  BAZZOOK [ Thu Jan 27, 2011 4:14 am ]
It was on the car when I bought it. I've had some big loads on it
