It is currently Tue Nov 03, 2026 3:42 pm
Post Posted: Thu Jan 27, 2011 12:00 am
hey im just about to order 2x lockright lockers ..i was reading that i could get it with new spidergear cupler but can only be used in the rear
unless u upgrade ur front axle now my question is if i just but 2 x lockrights F/R can i later up grade the axles with out replacing locker parts.. does that makes sence lol
or should i just buy new axles and the lockrights with newspider gears ..
Vehicle: 2018 DMAX
Post Posted: Thu Jan 27, 2011 12:30 am
Ur stock front axels are 22 spline, rears are 26 spline. The couplers they sell are 26 spline, so you would have to use ur 22spline spider gears in the front if you want stock axels.. And then later on if you want togo to stronger axels, pull your diff apart and replace you spider gears with 26spline ones...
For the price of chromos atm, you may aswell just upgrade them and not worry about breaking shit, or haveing to pull it apart again. You can also reuse you stock rear spider gears, you wont need new ones.
Post Posted: Thu Jan 27, 2011 1:40 am
thanks for clearing that up :)
Users browsing this forum: Google [Bot] and 100 guests
