Joined: Thu Jan 20, 2011 10:15 am Posts: 151 Location: brisbane
Posted: Thu Jan 27, 2011 7:41 pm
hi there are heaps of different 2'' shackls around do they all do the same job are shackles worth the money an time? does it mess up the geometry of the suspension are there 1'' shackles available let me know every1 cheers
Joined: Mon Jan 24, 2011 12:45 am Posts: 10 Location: trailer park, SE qld
Posted: Thu Jan 27, 2011 11:02 pm
rolls your diff forward on the front setting your caster negative. no clue how much, won't be a gret deal though. just ask a suspension shop. if youre real anal about it you can get castor correction plates (like a wedge) to put between the axle and spring to set it straight again. also rolling the diff backwards on the rear means pinion wont sit parallel to transfer case, which might give you slight viabrations.
not actually sure, difference might be so small its non existant. just saying.
hope that helps a bit. n not sure on the shackle questions lol
Users browsing this forum: No registered users and 324 guests
