It is currently Fri Nov 06, 2026 1:28 am
Post Posted: Sat Jan 29, 2011 12:15 am
Gday
I need some solutions and help.. i was driving an hit a bump and from then on my whole speedo cluster has stop working, my km counter my fuel counter doesnt work eiter :? .. Any ideas???
Post Posted: Sat Jan 29, 2011 12:21 am
The speedo cable runs all that stuff, it runs from the transfer case to the back of the speedo cluster... Either its come loose at one end or you've crushed it...
I want my old sig back :(
Post Posted: Sat Jan 29, 2011 12:22 am
Start with the basics. pop the speedo head out jack the car drive the wheels checking the speedo cable is turning. Might just be chance that it happend at the same time.
Suzuki is my way of life.
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Sat Jan 29, 2011 2:00 am
the speedo cable only runs the speedo and the odometer haha, that happened to me too mate, the cable was hittin on my chassis until it snapped.
i recomend take the cluster out (easy job, alittle stuffin around) u have to drop the windscreen, cuase their is a plug that sits in the back of it to run the rev counter, fuel and temperature, oh and all the lights (ie. fuel, handbrake light)
95 Sierra SJ70 TinTop
Vehicle: MY2019 Jimny
Post Posted: Sat Jan 29, 2011 6:45 am
Check all fuses too.
Post Posted: Sat Jan 29, 2011 7:03 am
Thanks for all the help.. i pulled out the speedo and an remove the speedo cable and it was broken in half down near the transfer case. Replaced an now all good :)
Vehicle: 4wd
Post Posted: Sat Jan 29, 2011 9:05 pm
You don't have to drop the windscreen to get the cluster out
Watch out or you'll get sued.
Vehicle: SJ413 WT
Post Posted: Thu Apr 07, 2011 5:47 am
Thread revival.
Having the exact same issue, but haven't checked my speedo cable to see if it's snapped yet.
How exactly does the gauge cluster come out? I've removed half the friggen car and still can't pop it out. The hazard light switch is getting in the way. :S
Post Posted: Thu Apr 07, 2011 7:46 am
toastysteve wrote:
Thread revival.
Just use a lil bit of force, not enough to bust anything, but enough to get the cluster out... tight fit but that do come out..
Post Posted: Thu Apr 07, 2011 7:54 am
& speedo cable's don't need a screwdriver to remove em from the cluster, just pull em, they are designed to come off semi easy..
Post Posted: Thu Apr 07, 2011 11:09 am
I've found the cluster comes out easy if ya drop the sterring column, two bolts.
bye
Vehicle: 4wd
Post Posted: Thu Apr 07, 2011 11:12 am
You can also replace the cable without removing dash or cluster.
Vehicle: SJ413 WT
Post Posted: Thu Apr 07, 2011 11:20 pm
Cheers boys. As always, A grade info.
Will take a look tomorrow.
Users browsing this forum: No registered users and 84 guests
