It is currently Mon Oct 19, 2026 8:52 pm
Post Posted: Wed Mar 19, 2008 3:53 pm
just wondering 4h with out rear tail shaft conected ok??? had to drive about 25kms to home with no rear tailshaft only did about 75kmph but there was a bit of vibration isthat because of no rear tailshaft?
Post Posted: Wed Mar 19, 2008 3:55 pm
could of been an out of balance front shaft causing it, you wouldnt have noticed before cause you dont normally do high speeds on flat ground in hi4
I dont think you could or would of damaged anything
Vehicle: 75 Cruiser
Post Posted: Wed Mar 19, 2008 3:57 pm
shayne use to drive to work in front wheel drive because he never got around to getting a replacement rear shaft. I think he did that ages.
Post Posted: Wed Mar 19, 2008 5:14 pm
cheers fellas just seemed a bit different to drive but there was some vibration coming from maybe the transfer case
89 WT H/top 1.6 8v SPOA 2" B/L virtara power steer
Post Posted: Wed Mar 19, 2008 8:29 pm
rear tail shaft all balanced and new uni's not cheap damm it! was done by hardy spicer
Post Posted: Sun Mar 23, 2008 12:01 pm
hardy spicer does good work from what ive heard
Post Posted: Sun Mar 23, 2008 7:20 pm
yeah they did a really good job of the shaft now the other two will be getting booked in as the gearbox to transfer case is fyucked.
Users browsing this forum: No registered users and 246 guests
