Joined: Mon Aug 13, 2007 11:30 pm Posts: 1787 Location: Butler, WA
Posted: Sun Jan 30, 2011 9:38 am
Chasing the opinions of others here, what would you do in my situation?
Scenario is:
SV420 Vitara with a stuffed rear axle/carrier. While it is apart I want to take the opportunity to swap to 5.12 gears to return the gearing close to standard.
I already have a complete 10 bolt 5.12 rear that I purchased by mistake.
Should I go the quick, cheap & easy method and put the locker in the 10 bolt diff and slot the whole thing in?
Or should I go the lengthy and expensive option and chase up a 12 bolt 5.12 gearset just so I can keep it a 12 bolt (and that is the only benefit as far as I am aware)?
Does anyone have any experiences with both 10 & 12 bolt rears? Is there much difference in strength?
Joined: Sat Aug 12, 2006 11:30 pm Posts: 2511 Location: Adelaide SA
Posted: Sun Jan 30, 2011 10:07 am
stick with the easy to get 10 bolt, i cant see it being much weaker than a 12 bolt, its not as tho you've snapped the bolt holding the crown wheel to the carrier, other things will break before they do
Posted: Sun Jan 30, 2011 11:55 am
If the silver princess is running one that is good enough for me, cheers fellas the 10 bolt it is. Now I just need to find the axle and a steel front diff
Users browsing this forum: No registered users and 539 guests
