It is currently Wed Nov 04, 2026 10:35 am
Post Posted: Tue Feb 01, 2011 12:30 pm
hey guys today i noticed what i think is a my ball joint leaking basicly im talking about some seal behind hub and its leaked all into my rim what do i replace and how hard is it thanks
also is it a ball joint im talking about lol ta
Post Posted: Tue Feb 01, 2011 12:41 pm
http://www.suzistore.com.au/shopexd.asp?id=1183&bc=no
its all a case of undoing bolts, fitting seals, then doing all the bolts back up again, but expect it to take around 1.5hrs per side at least as you need to strip the whole diff down including taking out the wheel bearings and axles.
Post Posted: Tue Feb 01, 2011 12:59 pm
so its my hubs leaking at the back ? so should i do my wheel berings why im at it
Post Posted: Tue Feb 01, 2011 1:12 pm
rears are leaking?
have a read down the bottom of this thread, there are 2 really good write ups with heaps of pics.
http://www.auszookers.com/index.php?name=News&topic=2
Post Posted: Wed Feb 02, 2011 7:02 am
just put a swivel hub kit through my car ..not to hard a job at all..pretty messy..if you go that far might as well do the wheel bearings ,,not included in the kit ..got the same kit on ebay for $89..Both my hub seals were completly shot..
Vehicle: Daisy
Post Posted: Wed Feb 02, 2011 7:58 am
Damn, my right front is leaking, not to the point of dripping on the floor though so I might leave it a while yet.
I'm guessing it just leaks the diff oil out?
your hub should have grease in it, not oil. I'd say your axle seal is leaking.
Vehicle: Daisy
Post Posted: Wed Feb 02, 2011 8:01 am
I realise the hub should have grease in it, I was just wondering if it sealed the oil in the diff+axle or there was an actual axle seal in the front.
It just looks a little wet, I was looking for a grease point but saw no grease nipple on the hub so as you've said I assume it's coming out of the diff :(
Unless I'm lucky and it's just melted grease, although it's looking a little too thin for that...
Post Posted: Wed Feb 02, 2011 8:39 am
hey heres some photos of it
Vehicle: 2018 DMAX
Post Posted: Wed Feb 02, 2011 8:55 am
The oil will have to get past the grease and scrapers to leak onto the swivel hub.. Check this picture, this is the oil seal that will be leaking, into where the CV sits and the grease is..
Vehicle: Daisy
Post Posted: Wed Feb 02, 2011 9:30 am
Damn internet dropped and my last post didn't work.
Mine looks to be leaking the same as that one tryhard posted, nowhere near as bad though.
Also that seal looks like a bugger to get to!
Post Posted: Wed Feb 02, 2011 9:43 am
so guys anyone know what i need to buy to fix this and what i should change do why im at it ..how hard is this job thank s
Vehicle: 2018 DMAX
Post Posted: Wed Feb 02, 2011 10:12 am
http://www.lowrangeoffroad.com/suzuki/s ... -kits.html
Thats the kit i brought..Iv have seen them for $80 without wheelbearings on ebay.. but im not sure what quality is like
Post Posted: Thu Feb 03, 2011 5:50 am
might cost a few $$ but you should replace: axle seal, hub seals, kingpin bearings and wheel bearings.
if you want to be a typical suzuki driver and not spend that much money then just replace the axle seal.
here's how you do it:
1 remove wheel and freewheeling hub end cap, remove circlip from end of CV shaft
2 remove brake caliper assembly
3 remove brake rotor
4 undo the 4 bolts that are now exposed from removing the rotor, split housing and remove.
5 remove CV from diff housing
6 replace axle seal
7 refit in reverse order.
this procedure is a simple task as kingpins, hub wiper seals and wheel bearings do not need to be touched. however if you don't know when they were done last I recommend doing the lot.
Post Posted: Thu Feb 03, 2011 8:28 am
Tryhard - yours looks like an axle seal - definitely do wheel bearings at the same time - often a collapsed bearing destroys the seal too.
Post Posted: Thu Feb 03, 2011 5:40 pm
hey guys thanks for the advice i think i might just replace the seal and do rest in a few weeks time when i order my front locker and cromolys axle shafts
thanks mrw82
for the guide
it only needs to wheel once at powerlines then its taking a brake lol got a long list of upgrades to do
Post Posted: Sat Feb 26, 2011 7:05 am
hey fellas, doing mine now but my question is, you got two bearings at the top & bottom of the housing, with the bearing races. i cant seem to remove the races. do i just slap in replacement bearings? my kit came with replacement races but i cant seem to remove the old ones.
cheers.
Vehicle: 2018 DMAX
Post Posted: Sat Feb 26, 2011 7:09 am
The way i did it was to use a flat blade, come down thru the race at the top and onto the inside of the race at the bottom. Tap one side, then tap the other one and so on. Than flip over and do the same. There should be a tiny lip that you can get onto on the inside of the race..
Post Posted: Sat Feb 26, 2011 7:17 am
cheers mate. ill give it a shot.
also the workshop manual says i gotta cut the swivel seal to fit... but the one i removed wasnt cut?? what the
Vehicle: 2018 DMAX
Post Posted: Sat Feb 26, 2011 7:55 am
Its tight but should fit over.. Mine did anyway..
Post Posted: Sat Feb 26, 2011 8:11 am
i am doing this tomorrow, was fun pulling it all apart few months back.....
My Maruti build, Click WWW
Post Posted: Sat Feb 26, 2011 8:20 am
ok i slipped it over. now im confused after removing the kingpin bearing races, i put the new races in, but now i cant seem to get the new bearings into those races... lol.
anyway, very messy indeed... looks like i gotta buy a tub of grease. any brand suggestions?
cheers
Vehicle: 2018 DMAX
Post Posted: Sat Feb 26, 2011 8:25 am
you put the races in the right way? Knocking em out when there in the wrong way, and not damaging them mite be hard. As for grease, i just use highpressure bearing grease...
Post Posted: Sat Feb 26, 2011 8:36 am
the side of the race with the lip faces outwards from the hub right? thats from what i observed as i hammered them out
Vehicle: 2018 DMAX
Post Posted: Sat Feb 26, 2011 8:49 am
On the right is what it should look like.
Post Posted: Sat Feb 26, 2011 10:06 pm
damn i put it in the wrong way... thanks mate.
off to the shop to get another two races, i dont think theres any chance of getting the old ones out beside using a dremel.
Post Posted: Sat Feb 26, 2011 10:38 pm
I just knocked them out with a center punch ?
Users browsing this forum: Google [Bot] and 94 guests
