https://auszookers.com/forum/
Brake problem
https://auszookers.com/forum/viewtopic.php?f=5&t=18770
Page 1 of 3
Author:  RUN.10W [ Wed Feb 02, 2011 6:34 am ]
Post subject:  Brake problem
Hi again
Sorry to be of a pain but im at my wits end with this car. I have had pedal pressure problems for a while now and slowly been changing stuff, today i put a new brake master cylinder in it had my fingers crossed this would sort it though it hasn't. Now when i take the vacuum hose off the booster and put my finger over the end of the hose the pedal goes good and i have great feeling brakes, though once i take my finger off the hose the motor stalls as it should. Once i put the vacuum hose back onto the brake booster the pedal goes soft again and when i pump the pedal to get a little bit of brake the engine stalls. Also when i disconnect the vacuum hose it always has pressure in it and lets it all out when i take it off the booster? Its a 1996 coil model sierra if it helps with a bias valve in the rear if that helps.
any help will be great guys.
thank you
Author:  Joe [ Wed Feb 02, 2011 6:38 am ]
Post subject:  Re: annoying
I seen the tittle to this and i thought it was gunna be a thread about Hotshit or Monkey :lol:
Sorry Mr 10W i can't help with your question :oops:
Author:  RUN.10W [ Wed Feb 02, 2011 6:39 am ]
:) sorry for the disappointment Mr Joe :)
Author:  Hotshot993 [ Wed Feb 02, 2011 7:15 am ]
Haha same I thought here we go, a thread bagging me out. And yeah sorry no help either.
Author:  atari4x4 [ Wed Feb 02, 2011 7:27 am ]
Grimbo will tell you what is annoying....
When someone else comes across this thread titled "annoying" 18 months later when looking for answers about brake problems & a soft pedal.
Hotquaterpounderwithnopicklesandsmallfireshaventyougotsomeburgerstoflip993
Author:  RUN.10W [ Wed Feb 02, 2011 7:41 am ]
Wonder if by any chance I might get some help or advice ha ha
Author:  Kermy87 [ Wed Feb 02, 2011 7:47 am ]
Sounds like a sota similar problem I had with one of mine, well still is a problem,,, I just bypassed it :) ,,,sounds like the power booster has hole in it somewhere, and the engine is stalling because it's getting way too much air through air leak in the booster
Author:  Built4thrashing [ Wed Feb 02, 2011 7:48 am ]
try reposting with a short description of your problem in the thread title
Author:  Hotshot993 [ Wed Feb 02, 2011 7:52 am ]
What are you on about here atari?
Author:  Teracis [ Wed Feb 02, 2011 7:57 am ]
Just edit your original post to change the title.
Also, I've not done much with brake lines e.t.c but can you isolate each section and see if it clears the problem? i.e. remove rear line and cap, if it fixes it your problem is to do with the rears. e.t.c
Author:  steak_knife [ Wed Feb 02, 2011 8:12 am ]
Booster is meant to make the peddle soft, that's what it does, It adds no breaking "power" at all..
Adjust your rear brake's....
Author:  atari4x4 [ Wed Feb 02, 2011 8:18 am ]
sorry Hotspellchecker993... it's not often that i write the words fries & i got 2 letters the wrong way around, maybe you should spend more time proof reading your own posts :wink:
Author:  Hotshot993 [ Wed Feb 02, 2011 8:40 am ]
Haha I was just being a smart arse, didn't really care.
I had to take advantage of the opportunity as it doesn't come up very often:)
Author:  RUN.10W [ Wed Feb 02, 2011 9:03 am ]
Rear brakes have been capped off, same problem,
Steak knife rear brakes have been adjusted.
Author:  shep [ Wed Feb 02, 2011 9:11 am ]
Post subject:  Re: Brake problem
are the front brake flex lines swelling?
Author:  RUN.10W [ Wed Feb 02, 2011 9:28 am ]
No mate haven't seen nor felt any swelling in the front brake lines either.
Author:  steak_knife [ Wed Feb 02, 2011 10:18 am ]
It could be the booster, but doesn't really sound like it, normally if the booster goes & you lose peddle it will make a hissing noise on application of the brake's..
can you get you hand's on a booster to try??
Author:  RUN.10W [ Wed Feb 02, 2011 10:20 am ]
Yea I may be able to get a booster from a mates car to try, thanks mate
Author:  steak_knife [ Wed Feb 02, 2011 10:20 am ]
Are coily's plastic booster's??
Author:  bagnkat [ Wed Feb 02, 2011 6:05 pm ]
No.
Author:  bagnkat [ Wed Feb 02, 2011 6:12 pm ]
RUN.10W wrote:
Hi again
thank you
If it's the booster side you're disconnecting, then the booster will leak air because the check valve is in the hose. I'm guessing you've already flushed and bled the brakes?
Author:  RUN.10W [ Wed Feb 02, 2011 6:51 pm ]
Yea mate have bleed the brakes a million and one times now, yea I do take the hose off the booster end.
Author:  JrZook [ Wed Feb 02, 2011 11:08 pm ]
How do you define braking power? If i drove my car down a hill with the booster attached it would deffo pull up a lot easier and quicker than non boosted. Doesn't it help boost the pressure applied to the piston in the master cylinder?
To the OP have you tried adjusting the pushrod in the booster?
Author:  stockman [ Wed Feb 02, 2011 11:30 pm ]
Isn't there a diaphgram in the booster?
Author:  JrZook [ Wed Feb 02, 2011 11:51 pm ]
yep
Author:  royce [ Wed Feb 02, 2011 11:56 pm ]
It doesnt make the brakes work any better, just reduces the amount of pressure you need to apply to the pedal
You should never have to adjsut the pushrod in teh master or booster and not unless you have the manual to tell you what to fo, cock it up and you can end up with a mastercyl that isnt releasing pressure properly so the brakes drag or the booster always slightly on making the engine run funny
Author:  stockman [ Thu Feb 03, 2011 12:31 am ]
JrZook wrote:
yep
What would be the out come it was split?
Author:  royce [ Thu Feb 03, 2011 1:07 am ]
stockman wrote:
JrZook wrote:
yep
Usually the engine will idle high or stall when you press the brake
Note this is press the brake, not pump the shit out of the pedal and wonder why the engine stalls and call it a fault, almost every engine will do that
Author:  RUN.10W [ Thu Feb 03, 2011 1:30 am ]
Thought have to pump to get some brake pedal...
Author:  masterA [ Thu Feb 03, 2011 2:15 am ]
I had a similar problem with the Nissan Pulsar only to find that the rear brake cyl were leaking?!
You said that you capped the rear brakes off so this shouldn't be a problem but still worth checking
Was the master cyl brand new or reconditioned?
Page 1 of 3 All times are UTC + 9:30 hours
